HPOP swap... - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-23-2013, 08:36 AM Thread Starter
Gaius's Avatar
Quoted: 50 Post(s)
HPOP swap...
I usually just dig in and tackle something new, but I only have an afternoon to change HPOP on Tuesday before I head back to work, then leave for buck season.
How long to swap the HPOP? I'm installing a used 17* pump, and have all new o-rings and gaskets. No more than a couple hours I'm thinking? Any tips?
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #2 of 12 Old 09-23-2013, 08:55 AM
Arcturus's Avatar
Only tip I can give is to try and pump out the HPOP reservoir first or you'll end up with a close to a quart of oil in the valley. Also may be pretty difficult if not impossible without removing the fuel bowl, unless you got e-fuel already.
Dieselsite instructions: http://dieselsite.com/pdffiles/adren...structions.pdf
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #3 of 12 Old 09-23-2013, 08:59 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
Half a day for the first time, shorter next time as you will be better at it and you will have changed to E-Fuel . You should pull the fuel bowl to do this.
Crack HPO lines at the HPOP, pull fuel bowl, drain/suck oil from the HPOP sump to keep things from becoming a mess, remove sump cover, remove HPOP drive gear access cover from front cover to access drive gear bolt, carefully remove bolt so as not to drop it into the front cover, slip off gear, remove HPOP retention bolts (I believe there are two) from the exterior of the front cover, remove HPO lines, unplug IPR, carefully remove HPOP toward the rear.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 12 Old 09-23-2013, 09:00 AM Thread Starter
Gaius's Avatar
Quoted: 50 Post(s)
Yeah, sucks to pull the fuel bowl, but at least it's pretty quick. All my hoses are new.
Thanks for the link!
05 F350 Crewcab
Gaius is offline
post #5 of 12 Old 09-23-2013, 10:06 AM
superduty4x4's Avatar
You can use a shop vac to suck the oil from the HPOP res by building a simple, oversized Mityvac style setup. I used to have pics of my setup but... drill 2 holes in a jar lid or other container (I used an old pickle jar) and poke hoses into them. Connect one hose to the shop vac and run the other into the HPO reservoir. Seal it up as best you can, fire up the shop vac and watch it work. It's really not that bad of a job, I did it in a couple hours in the dark one night.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #6 of 12 Old 09-23-2013, 07:23 PM
around 2 hours labor time, add another hour for rtv cure time... theres a very good instruction list on riffraff, it breaks it down step by step.. very helpful.. cheers
2002 7.3 with the basics.... 4in tb, cold air, dp tuned, autometer pillar... feel free to make donations
fl-diesel is offline
post #7 of 12 Old 09-23-2013, 07:25 PM Thread Starter
Gaius's Avatar
Quoted: 50 Post(s)
Good tip, was going to buy a vacuum pump tomorrow. I'll give this a try. Thanks!
I also have a severely smashed thumb, was off for a week. Went back to work yesterday, hoping I didn't pop a fire. It HURTS.
05 F350 Crewcab
Gaius is offline
post #8 of 12 Old 09-23-2013, 08:17 PM
Quoted: 890 Post(s)
Feedback Score: 3 reviews
The hand vacuum pumps used to change oil in boats works very well.
Something like this but u can find them less expensive.
http://www.wholesalemarine.com/boati...lity-pump.html
Corey@CNCFAB is offline
post #9 of 12 Old 09-23-2013, 09:11 PM
desertdeer's Avatar
Get all new fuel lines before you start. Without a doubt you will screw them up when you remove the bowl
96 F250 PSD 3''DP 4'' ATS EXHAUST 6637 TS-6 5-SPEED LUK CONVERSION INTERCOOLER PROPANE 4'' LIFT 35X18'S
desertdeer is offline
post #10 of 12 Old 09-24-2013, 06:33 AM
I've pulled many different bowls many different times and never damaged a line, trucks ranging from 150k to 250k miles and several of them were still running OEM fuel lines. You just have to be careful. Besides, OP already said his fuel lines are new.
