Single injector change without draining rails? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 09-23-2013, 08:17 AM Thread Starter
cthom388's Avatar
I am wanting to change my number 3 cyl injector. Is it possible to just pull the old injector out and quickly insert the other one without draining everything.
1995 F250 4X4 Zf5
  • TS 6 POS Power-Struck Tunes
  • 3" Silverline Dp to Straight Pipe
  • Custom E-Fuel/Regulated Return
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #2 of 13 Old 09-23-2013, 08:51 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Not worth the risk. There is a good chance that the copper seal at the bottom of the injector will stay in the cup rather than come out with the injector and you will then watch all the oil and fuel run into the cylinder till you can get a tool into the cup to pull out the seal. Draining the fuel is easy as is draining the HPO. Cleaning an oil spill into the cylinder, too me, is not worth the the time as compared to waiting for the HPO and fuel to charge back up.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 13 Old 09-23-2013, 09:06 AM Thread Starter
cthom388's Avatar
Thanks for the advice! So i should just pull both plugs out and drain the fuel bowl?
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #4 of 13 Old 09-23-2013, 09:18 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
No matter what you do you will have drainage into the cylinder. Pull the plugs inside the VC area (not the ones in the valley or the ends of the head). Drain as much as will come out. Fuel, like the HPO, is stored above the injector so draining it will only remove a little of what is there. What you are really doing by "draining the system" is relieving the pressure built up on the injectors. This pressure is what would drain more than normal fluid into your hole.
So relieve the pressures, pull the injector, clean the cup as best you can but do not use a cotton rag to check for loose old injector parts (these parts are machine cut which would pull/tear the rag leaving tufts in the cup, I use shotgun swabs crumpled on a long needle nose pliers), lub/install/lube again the new injector and o-rings, install injector, torque, pull glowplug, pull fuse 22, throw a heavy rag (wifes' beach towel) over the glowplug port bump the starter a couple times till the cylinder is clear, install glowplug and start the truck. She will smoke for a while, this is normal as the cylinder and manifold are going to be holding some of the spilled oil in them.
Matt
'97
-Stage II trans.
BigFuel is offline
post #5 of 13 Old 09-23-2013, 09:36 AM Thread Starter
cthom388's Avatar
Awsome man i really appreciate the quick reply!
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #6 of 13 Old 09-25-2013, 06:59 AM Thread Starter
cthom388's Avatar
So i got it changed out fine and it runs good now but its sounds like its got a kind of miss at idle. I went out and started it this morinig and it idled fine so i guess its when its warmed up. I can rev it up and it will idle down good then for a second or two it idles good then it starts missing again.Any ideas on cause?
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #7 of 13 Old 09-25-2013, 08:15 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
How many miles on this injector? Do you have a DVOM? Pull the VC connection to that injector (in the valley, not under the VC). Set the meter to OHMs and put one lead to the center of the 5 pins in the connector. Put the other lead to each pin to the left and right of the center pin. What is the reading in those two systems?
Matt
'97
-Stage II trans.
BigFuel is offline
post #8 of 13 Old 09-25-2013, 08:22 AM Thread Starter
cthom388's Avatar
I will have to wait to test them tell i get home but the injector is a thoroughbred reman
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #9 of 13 Old 09-25-2013, 08:24 AM Thread Starter
cthom388's Avatar
the other injectors are stock with 160,000 on them
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #10 of 13 Old 09-25-2013, 08:30 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
I think that those are actually Industrial Injection remans. I don't know much about that company but right off im not worried so much about that yet. Do you also have a way of running buzz and contribution tests? iIf the truck only has a couple miles on it since your swap this man simply be air in the HPO or fuel system.
Matt
'97
-Stage II trans.
BigFuel is offline
