OBD 2 scanner - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-22-2013, 06:02 PM Thread Starter
dirtcrew51m's Avatar
Quoted: 6 Post(s)
OBD 2 scanner
Found an old post, and it seems the Autoenginuity is the scanner to get for our trucks, are they the ones that tether to the laptop on ebay for around $120.00?
dirtcrew51m is offline
post #2 of 3 Old 09-23-2013, 11:59 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Don't know if you can get it that cheap, it does use an interface to a laptop (or other worstation), but it does need to have the Ford bundle to be used on the PSDs. Cheers!
Patrick Feeley is offline
post #3 of 3 Old 09-23-2013, 02:36 PM Thread Starter
Quoted: 6 Post(s)
Thanks, that is where the other $200.00 comes in.
