Looking for a wire - Ford Powerstroke Diesel Forum
post #1 of 16 Old 09-22-2013, 05:42 PM Thread Starter
vandy's Avatar
Looking for a wire
I need a wire that comes off my ingition, is "hot" to start the vehicle but goes dormant (if I can use that word...) once she's started. Basically that I could disconnect while running and not disrupt my truck. But if left disconnected and the truck was shut off, it would not restart.
Anyone know of any?
vandy is offline
post #2 of 16 Old 09-22-2013, 06:46 PM
Wicked6.0's Avatar
The only wire that does that in the ignition harness its the starter wire itself.
2005 F250 Lariat Ex Cab long bed 6.0 diesel. 4" Turbo back exhaust, Edge Insight CTS, High idle mod to upfitter, Blue spring, 6.4 Banjo Bolts, Coolant filter, Egr Delete, STC fitting upgrade, New oil cooler (9-5-11)
Wicked6.0 is offline
post #3 of 16 Old 09-23-2013, 06:38 AM Thread Starter
vandy's Avatar
Any idea on a wire color?
vandy is offline
post #4 of 16 Old 09-23-2013, 06:50 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The glow plug relay comes on and goes off after a minute or so when you start the truck as well
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 16 Old 09-23-2013, 06:53 AM Thread Starter
vandy's Avatar
That wouldn't stop the truck from starting would it? Might make it harder but assuming its warm it "could" still be started correct
vandy is offline
post #6 of 16 Old 09-23-2013, 06:57 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I'm not saying remove it, just tap it
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 16 Old 09-23-2013, 07:10 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Anyone know of any?
Your looking for a no start switch arent you? That might be a little better to say to explain it although i know your probably worried about security because i read your other thread about security systems. But the one to get what you want done is the neutral safety switch wire(if yours is an automatic) or the clutch safety switch wire(if yours is manual).
Its what prevents you from starting the truck when your truck is in reverse or drive(for auto) or in gear(for manual). As for where they are on the OBS idk for sure but im sure its up under the dash somewhere. Someone else may chime in to let you know
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #8 of 16 Old 09-23-2013, 07:11 AM
Wicked6.0's Avatar
It should be red/light blue. But use a multimeter to find out and be sure.
post #9 of 16 Old 09-23-2013, 07:13 AM Thread Starter
vandy's Avatar
Exactly correct sir. We have had several rigs stolen lately. I'm looking to put a reed switch in to prevent that from happening. Didn't think about the neutral safety switch. But that's a great thought
vandy is offline
post #10 of 16 Old 09-23-2013, 10:48 AM
Quoted: 53 Post(s)
On both manual and automatic trucks, there's a four-wire connector down by the brake pedal. On manual trucks, it connects to the clutch switch. On automatic trucks, there's a jumper plug that plugs into the connector, since it uses the neutral switch on the tranny. That would be a convenient place to wire in a kill switch in series.
madpogue is offline
