Storage Questions - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-22-2013, 03:09 PM Thread Starter
2147/7.3's Avatar
Storage Questions
I am about to storage my 96 f350 7.3 dually for an extended period of time, right around 3 years. While I am going to have my father due routine maintenance . I live in Indiana and wondering what are somethings that I should prep on the truck or I am not thinking about for the long period.
2147/7.3 is offline
post #2 of 9 Old 09-22-2013, 04:55 PM
If you are getting your old man to look after your ride then just get him to start the truck up every so often to keep everything lubricated and moving etc.
3 years is a long time for storage, would you not consider selling instead and buy another in 3 years?
Rob73 is offline
post #3 of 9 Old 09-22-2013, 07:28 PM
Arcturus's Avatar
definatley put in some anti fungal additive to your fuel. there are a number of products Like Biobor, Racor bio cide. I would think about a solar powered trickle charger to keep the batteries up to snuff.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #4 of 9 Old 09-22-2013, 07:55 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I'd wash and wax everything you can... Especially if it is sitting outside. Definitely add a fuel additive to keep the diesel clean. Tires can crack horribly from sitting in the sun for extended periods of time without being cleaned or covered. Why does the truck need to sit for so long?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 9 Old 09-23-2013, 03:16 AM Thread Starter
2147/7.3's Avatar
I am going to put the truck in a Barn or indoor storage. It is sitting for so long because I am in the military and am getting stationed in Hawaii for 3 years. I don't want to sell it because I love the truck. I mean it is a 96 with on 146K on it, plus I pull a 5th wheel with it. I will def. get something for the fuel. Other than that since it is sitting for so long I am going to take the battery out. My father is good with cars he is just not a Diesel guy so I want to make sure that everything is good for him.
2147/7.3 is offline
post #6 of 9 Old 09-23-2013, 06:48 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The military will ship your car/truck to Hawaii on their dime you know? But I guess when you come back state side you will be able to drive it too
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 9 Old 09-23-2013, 08:02 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
NO, don't ship to Hawaii! Fuel prices SUCK in Hawaii. Once you are there get a beater or a motorcycle and the fuel won't kill you. Would like to add that you ought to cover the nooks and crannies of the engine with dryer sheets. Rodents don't care for the stink of dryer sheets. Have pop's change them every 4-6 months too.
Are you Army Air Corps.? If so I know your new boss.................
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #8 of 9 Old 09-24-2013, 06:29 PM Thread Starter
2147/7.3's Avatar
No I am in the Marines. I already shipped my 02 Wrangler over that is why I am storing the 350.
2147/7.3 is offline
post #9 of 9 Old 09-24-2013, 06:50 PM
jse51599's Avatar
One small thing to add about the tires. If they're in good shape, and the truck isn't being driven, maybe a set of jack stands for the truck to sit on to keep the tires from getting flat spots.
6637, Diamond Eye Turbo Back, Riffraff Billet Intake Plenums and Intercooler Boots, WW2, Deleted EBPV
305 70 16 Toyo A/T IIs
Jim
jse51599 is offline
