gearing change-speedo Q - Ford Powerstroke Diesel Forum
post #1 of 25 Old 09-22-2013, 09:14 AM Thread Starter
Bullnose's Avatar
Im going to pull my f250 axles/springs with 4.10's and put in f350 springs/axles with 3.55's, Question i have is im assuming the speedo drive is in the trans, and set for 4.10's, whats the best way to get it reset so the speedometer is correct with 3.55's?
E-99 F350 XL 2wd reg. cab 7.3 auto trans all stock 226k
1997 F250 XL 4x4 ex-cab, 7.3, ZF-5 trans 4.10 gears, 3" down pipe, 4" exhaust, 5" tip, 150k
Bullnose is offline
post #2 of 25 Old 09-22-2013, 10:43 AM
the baconator
terryknight's Avatar
Quoted: 149 Post(s)
the speedo runs off of the tone ring in the rear. you won't need to do anything
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 25 Old 09-16-2014, 05:57 AM
Phillipjon's Avatar
Quoted: 78 Post(s)
So how do you correct for diff. size tires?
1996 F350 4X4 CCLB SRW
Full Force Stage 1.5-Swamps IDM-Efuel-Bosch 17* HPOP-Melling LPOP-Intercooled-Deleted pedestal-Stancor glow plug relay-1.0 housing-Isspro EV2's-Sky RSK-SD front and rear springs-Tru cool tranny cooler-Built Tranny-CCV mod-6 position chip running TW tunes-6637-3" down pipe to 4" straight pipe-Grab handle mod-Dual lighted visors-3.73 Gears-Warn hubs-SD aluminum rear diff cover-Dual front shocks-295/75/16 Toyo Open Country AT2's
Phillipjon is offline
post #4 of 25 Old 09-16-2014, 06:32 AM
the baconator
Quoted: 149 Post(s)
that is done through the PSOM, the speedometer in the cluster.
post #5 of 25 Old 09-16-2014, 06:33 AM
Phillipjon's Avatar
Quoted: 78 Post(s)
PSOM? If I go to 3.73 running my current tire size 295/75/16 I am trying to figure out my rpm at 70 MPH
post #6 of 25 Old 09-16-2014, 06:36 AM
the baconator
Quoted: 149 Post(s)
RPM = MPH * Gear Ratio * 336 / Tire Diameter
post #7 of 25 Old 09-16-2014, 06:40 AM
Phillipjon's Avatar
Quoted: 78 Post(s)
I am not too sure I fully understand.
post #8 of 25 Old 09-16-2014, 06:49 AM
the baconator
Quoted: 149 Post(s)
(70mph x 3.73 (gear ratio) x 336)/33.49 (tire size in inches) = RPMs
RPMs = 2619
The Following User Says Thank You to terryknight For This Useful Post:
Phillipjon (09-16-2014)
post #9 of 25 Old 09-16-2014, 06:53 AM
Phillipjon's Avatar
Quoted: 78 Post(s)
How do I take in account for the PSOM being off?
Right now doing 70 MPH the RPM's are 2250 or so with my 4.10
post #10 of 25 Old 09-16-2014, 06:54 AM
Phillipjon's Avatar
Quoted: 78 Post(s)
BTW that means that at 70 MPH on the speedo I am really doing 75MPH
