RPM Control - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-20-2013, 07:50 AM Thread Starter
RPM Control
Been meaning to find out what the small black box on the floor of my F350 is. I can say for sure its a digital tach, but it has 2 different buttons on it that say "RPM CONTROL" and "CHARGE PROTECT" along with a power button and some up and down arrows. I played around with it a bit, but nothing happended except @ one time the read out said 2100 in pressing some buttons. Engine rpm remained the same. Help?
1997 F350, 7.3 Crew cab, long box. All original....for now.
1969 Mustang. 302, Factory ac car.
460gashog is offline
post #2 of 5 Old 09-20-2013, 09:19 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It an aux idle control, is your truck auto or manual (aic for short)
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 09-20-2013, 09:21 AM
superduty4x4's Avatar
It's called an auxillary powertrain control module (APCM) or auxillary idle control (AIC).
https://www.fleet.ford.com/truckbbas...pcm_manual.pdf
Check out the link, it will tell you everything you need to know. If the "BRAKE" light in your dash doesn't come on with the e-brake set, do what I did and just run the wire that goes to the e-brake sensor to a switch.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #4 of 5 Old 09-20-2013, 09:49 AM Thread Starter
Automatic.
post #5 of 5 Old 09-20-2013, 11:41 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Click the link he gave, gives a full instruction manual
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
