Fuel additives - Ford Powerstroke Diesel Forum
post #1 of 15 Old 09-19-2013, 07:51 AM Thread Starter
Fuel additives
Not finding much for the 7.3 crowd. Lots of info if you have a 6.0 or 6.7. any insight? Ive heard everything from ATF to a cap full of stroke oil in each tank. I live in MN and have the lovely bio blen in EVERYTHING. Looking to protect my inj/pumps.
1997 F350, 7.3 Crew cab, long box. All original....for now.
1969 Mustang. 302, Factory ac car.
460gashog is offline
post #2 of 15 Old 09-19-2013, 08:23 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I just add howes diesel treatment to every full tank (about 4-6 oz), other than that I find the bigger fuel stations that tend to stay busy
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 15 Old 09-19-2013, 08:33 AM
Arcturus's Avatar
Bio Blends should have everything you would need with no additional treatment needed except for maybe cold weather keeping it from gelling. The goal of most additives would be for adding lubricity due to the ultra low sulphur mandated fuel. Using bio blend negates having to add lubricity. As far as cold weather gelling I can't speak to, I live in a warm; climate and rarely dips below freezing.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #4 of 15 Old 09-19-2013, 10:12 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
If you were anywhere near me in so cal it never got to freezing period but high 40's at night lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 15 Old 09-19-2013, 10:31 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Stanadyne Performance Formula worked well for me when I used it (stopped using it simply due to fuel costs). Cheers!
Patrick Feeley is offline
post #6 of 15 Old 09-19-2013, 01:27 PM
Arcturus's Avatar
It dips down here in the bay area. We actually get thin ice on top of puddles a few times every winter!m
JackT
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #7 of 15 Old 09-19-2013, 03:51 PM
Maverick1701's Avatar
Send a message via AIM to Maverick1701
I have run 2-stroke oil and diesel kleen with good results.
ChrisChris
2003 Kawasaki KLR650
1997 Ford Expedition 4x4
1967 Kaiser Jeep M35A2 6x6
2016 Silverado 4x4 Crew-Cab LS/Police
Maverick1701 is offline
post #8 of 15 Old 09-19-2013, 05:43 PM
95redrifle's Avatar
Quoted: 4 Post(s)
I use power service and i think it helps alot. Less smoke on cold starts and seems to idle smoother.
Sent from AutoGuide.com App
tony
1997 F250 4.10's
D60 swap/mag-hytec rear diff. cover
ts 6 pos./Autometers
melling LPOP/T-500 HPOP
D66 w/1.0 housing and WW2
160/80 rosewoods/bellowed up-pipes
08 king ranch seats/center console
south bend clutch
95redrifle is offline
post #9 of 15 Old 09-19-2013, 06:21 PM
Red '97's Avatar
Stanadyne here too, or diesel kleen. for winter diesel 911. have yet to try tranny fluid or stroke oil
-Conner
1997 F-250 Long Bed Extended Cab
--7.3 Powerstroke E40D Auto
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
-3 inch DP, 5 inch under truck, 6 inch Mitre!!
-2nd gen Wicked Wheel from Dieselsite
-Tony Wildman 6 Position Chip
Broke College Kid Mod
Now residing in LARAMIE, WY for school at the University of Wyoming! Hit me up if youre around, I'm always down for a hot rodding adventure
"Never cut what you can untie"
--Buckaroo Proverb
Red '97 is offline
post #10 of 15 Old 09-19-2013, 06:47 PM
kclough's Avatar
Not to high jack or anything but the two stroke oil how much should be added to help and could you put too much in
kclough is offline
