Questions on 94 F350 - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-18-2013, 06:13 AM Thread Starter
Good morning guys,
I am looking for a PSD for a work truck, will be doing home building. Saw this 94 PSD fairly close to home for me and am wondering if the body is too beat up to make the low miles worth it. Also, what would be reasonable price range if it runs well? I don't want to spend more than $4,000 on one if I have too.
Supposedly only has 65k miles, I do not know about transmission or what trim level it is, I have inquired about it, found it on Craigslist.
Attached is a picture of it
EDIT: I usually am not a fan of purchasing a truck that I know was used as a plow truck because you never know how much wear and tear was put on it, should that be a concern on this one?
Thanks guys!
Learning a lot just reading away
ID:	169601   Click image for larger version
Nowiser is offline
post #2 of 12 Old 09-18-2013, 07:38 AM
Quoted: 50 Post(s)
Plowing is hard on any truck, even these. But if you're looking to get in under $4K, and want a 4x4, you're gonna get something, er, well-used. That truck is an XL for sure. First, you want to confirm that it's a PSD; there were three different diesel engines in the '94 trucks. If it's a PSD, then it has a manual tranny.
Given its commission, the 65k on the odometer belies the run hours on the engine. Still, it's probably equivalent to a truck with 150,000-ish miles, which is still pretty "young".
Thing to look out for is RUST. That salter - back of the frame, bed, rear axle, rear fuel tank, skid plates, etc. will probably be super crusty. Also carefully inspect the rad support for rust.
Good running engine, solid ZF5 and the Dana 60 up front are worth $4K, if that's what they're asking.
madpogue is offline
post #3 of 12 Old 09-18-2013, 07:42 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Agreed with this, big thing with plow trucks is going to be all the rust, if it's auto it will not be a powerstroke but an idi or turbo idi, still a strong and dependable motor, just not a powerstroke
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 12 Old 09-18-2013, 12:17 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Since a truck with a manual tranny could be any of the engines, you want to check the 8th digit of the VIN. An "F" denotes it came with a Powerstroke (7.3L DIT), a "K" denotes the 7.3L IDI Turbo. And IIRC, "M" denotes the normally-aspirated 7.3L IDI. Cheers!
Patrick Feeley is offline
post #5 of 12 Old 09-19-2013, 04:47 AM Thread Starter
So I have gotten some information from him, some of it was what I wanted to hear and some of it wasn't!
It is an automatic, so the PSD is out unfortunately. I understand the International isn't a power house but is it still solid and worthwhile?
He hasn't driven the truck much in the last 6 years, since he has owned it. He has not used the salt spreader at all.
I am thinking about waiting for a PSD to come available but I don't have an unlimited time to wait for one.
Thanks for all your help guys
Nowiser is offline
post #6 of 12 Old 09-19-2013, 04:59 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Still you shoul take a look, even not being the powerstroke it is still a dependable work horse to have around
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 12 Old 09-19-2013, 05:47 AM
Quoted: 50 Post(s)
Is it turbocharged?
madpogue is offline
post #8 of 12 Old 09-19-2013, 04:01 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
If it is a plow truck, the front springs are most likely wooped, you can tell how much by he amount of + camber in the front, check the u-joints, check and smell the tranny fluid, the rear spring and shock mounts, I paid $4700.00 w\ western plow, knowing all the work that had to be done, I wanted it, its getting hard to find our trucks here in NJ, and all of the above were replaced among other things, but to me it was worth it. I now have a good reliable obs 7.3 that will last for many years. Same with anyone, if you really want the truck and put some work in it, to some it might not be worth it, but for others it might be.
dirtcrew51m is offline
post #9 of 12 Old 09-20-2013, 12:25 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Not worth the 4k. MAYBE in snow season it would be worth that to someone who would make the money back plowing in ONE season. For a project truck, you would have THOUSANDS into it and it still would only be worth 4k
I bought one similar to it 2 years ago for 1000 then did some odds and ends and sold it for 3500(in snow season)
Again a 94 IDI non turbo auto XLT w 100k on it
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #10 of 12 Old 09-23-2013, 05:25 AM Thread Starter
Thanks for all the input guys!
I went and drove it on Sunday, and it was just too rough. The engine sounded and ran well, but it shifted around the low gears fairly roughly. Also would cut out when switching from 4wd to 2wd.
Rust was bad, most would have been able to be fixed, but under the driver side door was really bad, so bad that the floor board where the seatbelt connected was hanging about 3 inches below the truck, so there was essentially no anchor point, meaning the seatbelt was pointless.
Thanks for weighing in, like in most cases you never know till you go and check it out.
Nowiser is offline
