obs suspension - Ford Powerstroke Diesel Forum
post #1 of 18 Old 09-17-2013, 03:25 PM Thread Starter
M.F.E.'s Avatar
Question obs suspension
ok so I have a 95 f350 cc with a flat bed and 4 wheel drive and im not sure if someone has installed some add a leafs or anything in the trucks past. however I was wondering if there is any possible way to soften the ride up a little bit. It currently rides worse than a hay wagon! Going down the road it doesn't really bother me but when you take it off roading it throws you all over the place. If you hit even the smallest of bumps at anything but a crawl its terrible. Yes I know it is a 1 ton and it will ride rough, I'm prepared for that. But I know I cant be the only guy on here that likes to take mine off road and I know some of you all have to have a smother ride than what I do! I don't typically haul to much so I can accept lowering the load capacity a little bit.
Sad day to see it leave like that!
M.F.E. is offline
post #2 of 18 Old 09-17-2013, 03:53 PM
Sam Burton's Avatar
try a RSK with superduty leaf springs, It will get you some lift, the smallest one is 2.5 inches but it is supposed to make a big difference. mine is going in this week.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #3 of 18 Old 09-17-2013, 04:10 PM Thread Starter
M.F.E.'s Avatar
Thank you for that information. I googled it and it looks like something I may be very interested in doing. Is there a way to know what superduty code springs to go with. I was thinking of the 2.5" kit and thats about all the lift I would want. I dont want any additional lift from springs. I would like to keep the truck as practical as possible and as good of fuel economy as possible so I dont want to lift it more than that. Also other than the springs would there be anything else needed, for instance shocks, brake lines, steering components, anything like that or is the kit and springs all thats needed?
M.F.E. is offline
post #4 of 18 Old 09-17-2013, 04:22 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
V codes up front and b codes in the rear. John (97beast) installed a set of softer then v code springs up front and got slightly less lift but I don't know what code he used
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #5 of 18 Old 09-17-2013, 05:47 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
U code iirc, but yes rsk should soften it up a bit with sd springs
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 18 Old 09-17-2013, 05:49 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
remove your sway bar. it will ride much better.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #7 of 18 Old 09-17-2013, 07:42 PM
Quoted: 82 Post(s)
You might want to take a superduty or two off road before deciding to make the switch. Every superduty I've taken off road didn't do worth a crap especially in sand or mud because the springs are so soft that you get a bad problem with wheel hop.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #8 of 18 Old 09-17-2013, 07:47 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Sd springs and traction bars ftw
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 18 Old 09-17-2013, 07:51 PM Thread Starter
M.F.E.'s Avatar
So for a truck that goes off road you guys dont like the swap? I dont like how right now off road the suspension absorbs pretty much nothing. I just want it a little softer. has anyone done the swap and off road much?
M.F.E. is offline
post #10 of 18 Old 09-17-2013, 07:54 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
How old are your shocks?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
