Easiest way to access fuel ports behind heads - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-17-2013, 07:10 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I did e-fuel a month or so ago and ever since then ive been dealing with a very slow leak that is bad some days and others doesnt leak at all. Problem is i cut the tubes heading to the back of the heads and just double clamped some hose clamps on it and doesnt quite seal all the way. I didnt want to pull the turbo because i was lazy but now im sick of loosing green gold on the ground and want to fix it. Whats the easiest way to get at those ports. And am i correct they are 1/8 npt ports?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 7 Old 09-17-2013, 08:23 AM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
Pull the turbo and i believe you are correct.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 7 Old 09-17-2013, 08:26 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
As for pulling the turbo, can i just unbolt the turbo from the pedestal or does the pedestal have to come out at the same time? id rather not mess with the bolt in the back if i can get away with it
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 7 Old 09-17-2013, 08:40 AM
the baconator
Quoted: 141 Post(s)
pedistal has to come out at the same time. the pedistal bolts to the turbo from the bottom. you probably can get to the fittings without removing to turbo, but don't quote me. i vaguely remember a thread on here where a guy did that. use plenty of PB blaster or equivalent on the bolts. you will need a 15mm swivel socket for the bottom two collector bolts, a 13mm socket for the top two and a 10mm swivel socket (1/4 drive works best for the rear two) for the pedistal bolts. replace the o rings while you are in there. sometimes the bottom two collector bolts don't work with the swivel socket in which case you will need a wrench that has been made to fit
post #5 of 7 Old 09-17-2013, 09:10 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Is it possible to unbolt the turbo from underneath the pedestal? But now that im thinking more about it, i think i could just use compression tube fittings, that willl be alot easier. what size tube is it from the back of the heads?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 7 Old 09-17-2013, 09:46 AM
the baconator
Quoted: 141 Post(s)
compression fittings would be easiest. i want to say the lines are 1/4" but the may be 3/16" i can't remember. and there is no way to unbolt the turbo from the pedistal.
post #7 of 7 Old 09-17-2013, 10:20 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
I read a thread where a guy chimed in saying he did that but no one else was able to confirm that. Thats why i asked. But yea i suppose ill try compression fittings before i go tearing the turbo off and screwing up something else like i always do
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
