broke down with fuel leak and an axle leak - Ford Powerstroke Diesel Forum
post #1 of 29 Old 09-15-2013, 09:05 PM Thread Starter
M.F.E.'s Avatar
Exclamation broke down with fuel leak and an axle leak
To make a long story short I was on a long road trip and burnt threw the 2nd tank way faster than the first tank and realised there was a problem about the same time I smelled diesel. Pulled over and steam billowed every where. Found a major leak in the rubber hose that goes from the front of the drivers head to the front of the fuel filter. Couldn't fix it without a new hose so I had it towed. While waiting for the truck I saw the passenger side of my front axle was leaking gear lube. The truck was parked at an angle but still should not have done that. The truck is now 200 miles from home in the four corners area of New Mexico. My plan is to go swap the fuel hose, tope off the front end a few times and limp it home. Now will I have to blead my injectors or will I be able to get the truck to start? Also when it makes it home how hard will it be to reseal the front axle? Its a 95 f350 4door 4 wheel drive. I have only had the truck for a month now so it was sad to see it leave on the flat bed. Any advice is apreciated.... I could use it big time!!!
M.F.E. is offline
post #2 of 29 Old 09-15-2013, 09:27 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
You blew a return line. No worries there seeing as how it will bleed rather quickly and fire up. As far as the axle our axles only have inner axle seals. To replace that you are going to basically rebuild the whole pumpkin since it has to be pulled to get to the seal
Trucks and parts............
kanuck15 is offline
post #3 of 29 Old 09-15-2013, 09:34 PM Thread Starter
M.F.E.'s Avatar
I have never done that. Is it something that someone with basic to good mechanical know how can do? Or would I be in way over my head?
M.F.E. is offline
post #4 of 29 Old 09-15-2013, 09:50 PM
nine6stroker's Avatar
Quoted: 35 Post(s)
I rebuilt my whole front axle (has a pretty severe leak from the L/F axle seal). It really wasn't all that hard. It looks intimidating, but with a little patience and help you can easily do it yourself. When I pulled my front differential apart, I used a big socket to and small hammer to tap the new seals into place, and it worked perfect! The only issue I ran into was that I could not get the differential itself to seat back into place when I was reassembling it. Stuck the diff in the freezer for a few hours and it popped right back into place!
If I remember right, the front differential does not turn unless the hubs are locked in, so I think you'll be fine getting home with the leak. I would verify that before you try it though.
1996 F250 7.3 PSD 4x4 - "Dally"
281k miles
BDP stage 1's, T500 HPOP, TS6 chip, KC38r turbo, stock trans and fuel
Sitting on 2006 F-350 axles and suspension
nine6stroker is offline
post #5 of 29 Old 09-15-2013, 09:53 PM
kanuck15's Avatar
Quoted: 10 Post(s)
just pay good attention to how it all comes apart and put it together the exact same way. As far as what shims go where on the diff. You will be fine if you are careful with it
kanuck15 is offline
post #6 of 29 Old 09-15-2013, 09:56 PM Thread Starter
M.F.E.'s Avatar
Thats what I thought to so I was rather confused on why it started leaking with the hubs unlocked. i remember one time right after I got it I was crawling under it and could turn the drivers side u joint but not the passenger one. didnt think anything of it then. now im wondering if my passenger hub wont unlock. if it really was unlocked and the axle wasnt spinning why did it start leaking after a 250 mile drive but never leaked before?
M.F.E. is offline
post #7 of 29 Old 09-15-2013, 09:58 PM Thread Starter
M.F.E.'s Avatar
ok, so if i stick with the same shims i shouldn't need any measuring tools or to reshim it then? I don't have any specialty tools that's why im asking.
M.F.E. is offline
post #8 of 29 Old 09-16-2013, 06:58 AM
Quoted: 35 Post(s)
I don't either, I just made sure the shims went back where they came from. No problems so far, and that was probably 25 or 30k miles ago
281k miles
post #9 of 29 Old 09-16-2013, 12:44 PM Thread Starter
M.F.E.'s Avatar
For my axle seal is there any where that anyone has seen to get a seal kit for the hole front axle, by the sounds of things i should do them all. also for the rubber hose that goes from the front of the head to the fuel bowl everyplace I have talked to has said that is a ford only part. I dont really want to put another rubber on one because this one dry rotted and cracked so I would kinda like to replace them both with steel braided lines, has anyone done that or know if anyone sells them or should I just throw rubber ones in again?
M.F.E. is offline
post #10 of 29 Old 09-16-2013, 01:01 PM
kanuck15's Avatar
Quoted: 10 Post(s)
just go to a local hydraulic shop and they will fix you up. Ford ones suck
kanuck15 is offline
