Global renew and International factory reman - Ford Powerstroke Diesel Forum
post #1 of 18 Old 09-13-2013, 07:49 PM Thread Starter
Transmission or Injectors
lwillson's Avatar
Hey guys
I just added a new truck to the fleet. 97 F350, 5 SPD, 4x4, dually.
It has stickers as listed in the title, international factory remanufactured on the valve covers
Has anyone had any experiences with reman engines?
The catch was that something is wrong with the transmission or clutch. Nothing happens when you push the clutch , and you can shift through the gears.
lwillson is offline
post #2 of 18 Old 09-13-2013, 08:06 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It's gotta a pretty sweet flat bed on it, and damn I want your ccsb, sorry no experience with reman, but if it came from IH it should be the most updated, although all reman engines now from what I hear are pmr rods
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 18 Old 09-14-2013, 05:17 AM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
Originally Posted by lwillson View Post
Hey guys
long time no see, truck looks good so does the new one. what do you mean you can shift through the gears and the clutch does nothing?
the 97 i sold had a reman engine. had recpeits for $9K ish it was fine. same as the rest of them i assume. it was installed in 04 or 05 had about 60K on it when i sold it. it was done for IH so i assume it was to factory spec
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 18 Old 09-14-2013, 08:44 AM
Quoted: 50 Post(s)
Does the clutch pedal return when you let go of it?
So it does shift, but nothing engages? Yeah, hard to interpret what you're describing. Maybe the t-case is in neutral?
4x4 dually means it's been done in service. It'd be interesting to try to determine if it's a 4x4 that's been converted to dually, or a dually that's been converted to 4x4.
madpogue is offline
post #5 of 18 Old 09-14-2013, 09:10 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
They made 4x4 DRW in cab chassis models.
Larry, I can't seem to think anything would be wrong with having an IH rebuild. It has to meet factory specs which we all know is good enough.
Both trucks look good! Replacing mellow yellow?
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #6 of 18 Old 09-14-2013, 09:52 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I have a 4x4 dually (cab and chassis)
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 18 Old 09-14-2013, 12:25 PM
Quoted: 50 Post(s)
^^^ But was there an F350 C&C? I thought the C&Cs were all the "F-SuperDuty" (i.e. F450). And yeah, looking at the length of the frame, it looks like a C&C.
madpogue is offline
post #8 of 18 Old 09-14-2013, 01:14 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Yes it's an f350, you couldn't get one from ford that's 4x4 in the f-sd platform
1997 8 lug
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 18 Old 09-14-2013, 01:38 PM
ol_Blue97's Avatar
U could get them in 350 and f-superduty.
FRANK THE TANK
post #10 of 18 Old 09-14-2013, 02:59 PM
the baconator
Quoted: 146 Post(s)
what they said. we had a 350 C and C and have a F-SD. narrower frames both
