cold weather? - Ford Powerstroke Diesel Forum
Old 06-10-2008, 02:40 PM
cold weather?
I have a 97 F250 on 38's I'm looking for some info about them being in cold weather. I'm in florida now but goin to basic in 2 week's then I'm gonna be stationed in alaska and I'd like to have my truck, but woundering if their's anything I can do to help with cold weather. my truck doesn't seem to like cold weather starting and take's a long time to warm up. I'm either planning on buying a newer daily driver but I'd rather take it with me. any advise? and does anyone have any experiance how the super swamper SSR's are with snow and ice?
Old 06-10-2008, 02:48 PM
My truck does fine on cold weather.
Make sure you get your block heater hooked up. If you don't already have the plug, the connection should be under the front drivers side bumper.
If it going to be real cold then get the thinner diesel oil's.
I would make sure your glow plugs are in good working order. And you may need to cycle them a couple of times before starting.
When I hunt, first start up of the day I turn the key on for 2 minutes, then off, then right back on for a minute and it fires right back up. Then I let it warm up. (You will hear your EBPV when below 32*, not a problem just makes a loud hissing sound)
If all your fluids are good and designed for cold then you should be OK.
As for The Super Swampers, I would get rid of them and go with a tire designed for snow and Ice, not Mud. But then again I've never had a set, so I don't know.
