D60 help! - Ford Powerstroke Diesel Forum
post #1 of 26 Old 09-13-2013, 12:28 PM Thread Starter
problemchild55's Avatar
Quoted: 2 Post(s)
D60 help!
I found a donor truck for a d60 swap. It is an 89 f350. Going to get rid of the ttb junk on my f250. Looks like the donor truck has 3.55's. My f250 has 4.10s. Is it best to find another donor truck with a d60 and 4.10s or could I find a set of gears to swap in????? What do you guys think? Thanks!!
problemchild55 is offline
post #2 of 26 Old 09-13-2013, 01:16 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Be easier/cheaper to find one with the rite gears than to swap them, but hell use both axles in yours instead then
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 26 Old 09-13-2013, 01:18 PM
Sam Burton's Avatar
I agree, if you found a good deal on the one with 3.55s just use both diffs.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #4 of 26 Old 09-13-2013, 01:27 PM Thread Starter
Quoted: 2 Post(s)
Thanks for the replies! Yeah that's what I was thinking, but I do tow pretty often so if I put the the 55's in I don't want it to be a dog while towing.
post #5 of 26 Old 09-13-2013, 01:33 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
How heavy do you tow is the main thing, if it's pretty light then it won't matter much
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 26 Old 09-14-2013, 05:20 AM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
personally i wouldn't ever use 3.55s, i don't even like 3.73s. but it's what is available so sue them if you want working 4x4 instantly. or save up and find a set of 4.10s personally i would rebuild the axle before i out it in and if you go that route swap the gears then. and add a locker
you have the donor truck so you have everything you need which is a big plus.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #7 of 26 Old 09-14-2013, 09:01 AM Thread Starter
Quoted: 2 Post(s)
Yessir! I'm thinking I may do that. I'm also thinking about selling the whole truck and finding another 350. My f250 is just eating the tires away. And I'm getting tired of it. Thanks!
post #8 of 26 Old 09-14-2013, 09:02 AM Thread Starter
Quoted: 2 Post(s)
We tow pretty heavy sometimes so I don't think the 3.55s will benefit me. Thank you for the reply
post #9 of 26 Old 09-14-2013, 09:23 AM Thread Starter
Quoted: 2 Post(s)
Rear end tag. Is there any way to tell the gear ratio? Thanks!
post #10 of 26 Old 09-14-2013, 09:29 AM Thread Starter
Quoted: 2 Post(s)
