18x10 -24mm on OBS - Ford Powerstroke Diesel Forum
post #1 of 15 Old 09-12-2013, 07:37 AM Thread Starter
Lechlis's Avatar
18x10 -24mm on OBS
So here is the dilemma, I am getting a new set of rims soon and I am heart set on the Moto Metal 962s. I can get a package deal from rimzoneonline with 18x10s (-24mm offset) and Nitto Terra Grapplers (325/60r18). The only thing i'm worried about is how much will they poke past the fender? I know there will be rubbing at full lock and all that. Just curious if these are to wide and if I should just get 18x9s (0 offset) and 305/60r18s. Pictures would be great!
Lechlis is offline
post #2 of 15 Old 09-12-2013, 10:25 AM
HCSTROKER11's Avatar
Here is that setup. Pic in sig. On 35s. No rubbing at anytime with a little bumper trimming
1997 f350 4x4 off road.
353k miles
Stage 1 swamp injectors. TS chip. Leveled on 35" Federal tires and black 18 inch pro comp wheels
3" downpipe into 5" straight pipe 6" tip. (Diamond eye)
1987 Chevy 1ton lifted 24 inches on 53s. Duece and a half transfer case. Mud truck.
HCSTROKER11 is offline
post #3 of 15 Old 09-12-2013, 10:26 AM
Oh sorry. Just saw you have an f250. Yeah yours will probably rub.
353k miles
post #4 of 15 Old 09-12-2013, 12:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
F250 isn't that much different in height
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 15 Old 09-12-2013, 01:11 PM
Then why do people gain a good 2" when they do a Dana 60 swap
353k miles
post #6 of 15 Old 09-12-2013, 01:38 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
i would agree 1.5-2" difference
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #7 of 15 Old 09-12-2013, 01:51 PM Thread Starter
Lechlis's Avatar
HCSTROKER11 do you have any straight down the side pictures or a measurement of how much tire extends outside the fender?
Lechlis is offline
post #8 of 15 Old 09-12-2013, 02:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I gained maybe an inch overall up front, not a big enough difference IMHO, I fit the same wheels and tires under my f250 suspension as I did my f350 set up (305/55/20) same rub at full lock and every now and then I could catch the bumper
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 15 Old 09-12-2013, 02:38 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 49 Post(s)
You also had a full sized Semi tires on your 4x2.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #10 of 15 Old 09-12-2013, 03:17 PM
353k miles
