Driveshaft reinstallation Torques - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-11-2013, 02:26 PM Thread Starter
I am putting my driveshaft back together tonight and looking for the torques. i need the carrier bearing bolts, the front 12mm 12 point bolts that connect to the transfer case and the rear bolts that are the T-45 bit. Thanks!
powerstroke814 is offline
post #2 of 2 Old 09-12-2013, 08:30 PM
Gaius's Avatar
Quoted: 43 Post(s)
Not super important to get exact spec, I just use my elbow torque wrench.
If you want to torque them for your own piece of mind, and can't find them in a service manual, a standard bolt torque chart will get you where you need to be. Good luck!
Bolt Torque Chart | Portland Bolt
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
