72-Pin Connector on Firewall wont come un-plugged? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-11-2013, 01:56 PM Thread Starter
Pwnm30rdi3's Avatar
This sounds dumb, but I cannot get the large 72 pin connector to unplug from the firewall. The bolt holding the connector together seems to be stripped, it spends an endless amount of times in either direction. When I removed this plug last time I don't remember there being any clips holding it in, granted that was over 8 months ago.
Is there a trick to removing this sucker?
1997 F350
Mahle Ceramic Coated Pistons (De-lipped), Billet Crower Connecting Rods, DI Chromoly Push Rods, Beehive Valve Springs, Fire Ring Headgaskets, ARP Head Studs, Mike's Main Girdle, Melling LPOP, Terminator Dual HPOP, 300/200 Injectors, Dual SD Fuel Pumps, Billet Aluminum Intake Plenums, 6.0 Mishimoto Intercooler, Compound Turbos (Primary = 62/68 & Atmospheric 82/88), John Wood Tranny, 4921 Transmission Cooler, Batteries Relocated to Bed
Pwnm30rdi3 is offline
post #2 of 11 Old 09-11-2013, 04:13 PM Thread Starter
Pwnm30rdi3's Avatar
Is it possible to drill and tap the bolt in the plug?
1997 F350
post #3 of 11 Old 09-11-2013, 06:06 PM
I wouldnt drill and tap that.
The Bolt should become loose but shouldnt come out of the plug.
I havent disconnected mine in forever, and I would try it to tell you but I had that whole connector eaten up by squirrels and its spiced together.
williameub is offline
post #4 of 11 Old 09-11-2013, 06:08 PM Thread Starter
Pwnm30rdi3's Avatar
It almost looks like there are 2 clips holding it in but I'm not sure.
1997 F350
post #5 of 11 Old 09-11-2013, 06:27 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
the 2 clip looking things hold the other half in the firewall. there is only the bolt that holds it together. mine takes a 10 mm socket i think. can you take the inner fender well out to get better access are you trying to take it apart or put it back together?
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #6 of 11 Old 09-11-2013, 10:13 PM Thread Starter
Pwnm30rdi3's Avatar
I currently have the fender wells out! The bolt holding it together just keeps spinning and wont let the connector loose.
1997 F350
post #7 of 11 Old 09-12-2013, 03:18 AM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
did the 2 halves come apart at all , does it move by pushing it in or pulling apart. hard to believe that the bolt can be stripped . the bolt head isn't rounded is it
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
Isspro 3 Gauge Pod
Banks Big Head
298K
post #8 of 11 Old 09-12-2013, 05:56 AM Thread Starter
Pwnm30rdi3's Avatar
The two halves have not come apart at all and it doesn't move in or out. The bolt's head is not rounded
1997 F350
post #9 of 11 Old 09-12-2013, 07:22 AM
superduty4x4's Avatar
You probably are just spinning the thread insert in the other side of the connector. You're going to have to get creative with a drill or a dremel tool to cut the bolt head off and get it apart.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #10 of 11 Old 09-12-2013, 05:27 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
why do you need to take the connector apart? Could it be possible to get a pair of needle nose pliers on the bolt insert from the other side? or vise grip needle nose
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
Isspro 3 Gauge Pod
Banks Big Head
298K
