glow plug time? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-11-2013, 03:58 AM Thread Starter
M.F.E.'s Avatar
Question glow plug time?
I have a 95 f350 crew cab 4 wheel drive with 280000 miles and i have known that it could use glow plugs but its been getting harder to start. before i could cycle the key a few times and crank it and if it didn't start the first time it would start the 2nd time cranking it. now when its cold you can crank and crank and crank for ever. it will try to go every once in a while but just wont. but if you tap the gas pedal a bit then she will fire up. is this still just due to bad glow plugs or is there another issue? it runs fine once its running and starts right up warm. im leaving tomorrow for a weekend trip to lake Powell with the truck and wanna be sure she will be alright. also thank you every one on here for all your help. you have been a huge help to me, it is appreciated!
M.F.E. is offline
post #2 of 8 Old 09-11-2013, 04:48 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Either glow plugs or glow plug relay, go ahead and do both, your cold start issue will thank you, btw ever thought about plugging it in at night or in the morning before you go to start it?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 8 Old 09-11-2013, 05:40 AM
Quoted: 53 Post(s)
Cycling the key does nothing. The glow plugs stay on much longer than the WTS light. Just leave the key in RUN for an extra 10-20 seconds before cranking. But if indeed it requires that additional glow plug run time, that indicates either weak glow plugs or a failing relay. The relay can be in a state where it closes, but provides inadequate voltage to the glow plugs. Test - turn the key to RUN, and measure the voltage at both big terminals on the relay. The "always on" terminal will be slightly higher, but if the _difference_ (aka. voltage _drop_) is more than 0.3V, the relay is shot; it just appears to be working.
Tapping the pedal does nothing either. There's nothing mechanical attached to it. It's equivalent to pressing the volume buttons on the radio when it's turned off.
madpogue is offline
post #4 of 8 Old 09-11-2013, 06:42 AM Thread Starter
M.F.E.'s Avatar
Ok, I will have to look into those, so tapping the pedal while I'm cranking won't put a bit of extra fuel in there? And yea I can hear the solinoid clicking but I will have to voltage check it. If it won't start for me durring this trip because I don't have time to fix it before tomorrow would a touch of starting fluid be a terrible thing to use? And I have put thought into plugging it in but I really don't want to have to and here is why. Its not even cold yet and doing this. I want to use the truck to drive up the mountains in CO and go snowboarding all day. I won't be able to plug it in at the ski resorts so I'm going to need the truck to be able to start after a long cold windy day and maybe night on top of the mountain. With good glowplugs and a good relay would you think I could expect the truck to start or am I asking to much of the truck?
M.F.E. is offline
post #5 of 8 Old 09-11-2013, 06:53 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
It should do much better with good plugs and relay, but again, mite want to test to be sure it's the issue
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 8 Old 09-11-2013, 03:13 PM Thread Starter
M.F.E.'s Avatar
Come winter time is there any tricks I can do to help the truck to start after a long day or night of being parked on top the mountain in the snow? I wont be able to plug it in. would it be a terrible thing to use some starting fluid?
M.F.E. is offline
post #7 of 8 Old 09-11-2013, 03:45 PM
Quoted: 53 Post(s)
Do NOT use starting fluid except in DIRE emergency, and if you do, you MUST disable your glow plugs (or things go boom....). As said above, good glow plugs and a good relay, AND good batteries, should do you. The key is to remember that the glow plug run time extends well beyond the WTS time. We routinely park our truck at our cabin in the winter, no electricity, 0F for days at a time. Just leave the key in RUN for about 30 seconds, turn the key and let it crank an extra 5 seconds or so, and it lights right up. Critical factors are:
* good glow plugs
* strong relay (minimal voltage drop)
* strong batteries
* starter in good shape
* good quality winter fuel, anti-gel (e.g. Power Service white-bottle, etc) added for good measure
madpogue is offline
post #8 of 8 Old 09-12-2013, 08:09 PM
elrojo63's Avatar
Use Rotella 5w40 synthetic oil. It's much thinner at the colder temps. With the right oil, good glowplugs, good batteries, and good fuel you'll have no problems starting below zero. I used my truck every day commuting to night shift grooming on the mountain and never plugged it in.
1997 PSD Crew Cab Shorty Centurion Flatbed 234k D60 Swap
Leather Interior, built in radar detector, 5 inch dozer stack, DIY exhaust brake/TC lockup
1997 F-250 PSD ZF5 4x4 RCLB 362k SOLD
1953 Clark Carloader Forklift
1996 Subaru Legacy Wagon
2001 Big-Tex 16' Landscape Trailer
2006 Suzuki King Quad 750 27 inch ITP Mudlites
elrojo63 is offline
