Engine runs but accelerator pedal won't work? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 09-10-2013, 12:31 PM Thread Starter
Pwnm30rdi3's Avatar
Just got my motor started, finally. Did the hot-retorque and burnt my hands a good 10 times.
But I ran into another problem... The accelerator pedal won't work, the tach won't work, the oil pressure and engine coolant temp gauges aren't working. They were all working when I pulled the motor. Any tips?
1997 F350
Mahle Ceramic Coated Pistons (De-lipped), Billet Crower Connecting Rods, DI Chromoly Push Rods, Beehive Valve Springs, Fire Ring Headgaskets, ARP Head Studs, Mike's Main Girdle, Melling LPOP, Terminator Dual HPOP, 300/200 Injectors, Dual SD Fuel Pumps, Billet Aluminum Intake Plenums, 6.0 Mishimoto Intercooler, Compound Turbos (Primary = 62/68 & Atmospheric 82/88), John Wood Tranny, 4921 Transmission Cooler, Batteries Relocated to Bed
Pwnm30rdi3 is offline
post #2 of 22 Old 09-10-2013, 01:31 PM
Check your fuses. There is a fuse in your box that controls all of that stuff. I forget what its called though.
99' F-350 CCLB 92,100 miles ▬ 05 headlights 4" exhaust 6637 Gauges F650 dash blue LED interior HID Headlights & offroad lights 20" LED lightbar PHP Hydra 08 Taillights
97' F-450 Powerstroke 4x4
03' Peterbilt 379 650+ CAT
02' Cummins 3500 flatbed
peter379 is offline
post #3 of 22 Old 09-10-2013, 03:18 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Also check under your dash too, I've had that happen but skinny pedal still worked
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 22 Old 09-10-2013, 03:38 PM Thread Starter
Pwnm30rdi3's Avatar
Checked every single fuse on the truck. The only one blown was number 16 in the dash. 16 is for the cigarette lighter.
Skinny pedal is plugged in. Anything else I can check? I just keep having one problem after another...
1997 F350
post #5 of 22 Old 09-10-2013, 03:51 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Pull the column cover off and check to see if the wires coming out of the gear shift and run down the column are chafed or broken. I'll bet you'll find your problem there.
dhanna6powerstroke is offline
post #6 of 22 Old 09-10-2013, 04:00 PM Thread Starter
Pwnm30rdi3's Avatar
I will check, I just don't understand why it would just now be giving me a problem? The truck has sat for 8 months, un touched.
I need to pull the ignition cylinder out to get the column cover off, correct?
1997 F350
post #7 of 22 Old 09-10-2013, 04:01 PM
Mod Newbie
Quoted: 20 Post(s)
Yeah, but it comes out easy.
post #8 of 22 Old 09-10-2013, 04:03 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
^^^ is that what he said to her
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 22 Old 09-10-2013, 04:08 PM
Mod Newbie
Quoted: 20 Post(s)
post #10 of 22 Old 09-10-2013, 05:37 PM
dr.deere's Avatar
Quoted: 19 Post(s)
Sounds more to me like you have a ground issue. I e for got to connect one putting motor back in.
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
