possible issue? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-10-2013, 11:21 AM Thread Starter
vandy's Avatar
possible issue?
so this is 2 oil changes in a row this has happened and its got me slightly concerned.
go to change the oil, roll my fat a$$ under the truck, pop the drain plug out and watch her drain out. pull the filter, i have it up side down draining into the old oil container.
new filter on, dump 15qts back into her and go to put the old oil back in the new oil containers to get rid of.
4 containers go in the truck and only 3 came out? happened 2 times. i checked my oil level about 2 weeks ago and she was maybe a qt low and it was added.
am i missing something? dip stick level is showing good but im missing about 3.5 qts on the back side?
vandy is offline
post #2 of 4 Old 09-10-2013, 11:41 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Are you checking the oil level before you change it?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 09-10-2013, 11:57 AM Thread Starter
vandy's Avatar
no i didnt. i will be next time. but for 5k miles i had to add 2 qts. as far as i know i have no oil leaks in the summer. id imagine that much oil being missing id have some evidence of a leak on my driveway
vandy is offline
post #4 of 4 Old 09-10-2013, 03:20 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
It also turns to vapor and goes into the crank case vent
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
