motor diffrences - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-09-2013, 07:53 AM Thread Starter
forttravis's Avatar
motor diffrences
i have a 95 cc 4x4 that i am either going to rebuild the engine or replace and build. the question i have is besides the powdered rods is there anything else different in the 99 and newer motors or are the the same. any help would be nice
forttravis is offline
post #2 of 6 Old 09-09-2013, 07:58 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Long block wise the e99 has 120 cc injectors, and is intercooled, the L-99-03 has 140 cc both are split shot, and intercooled, the 99+ uses 1 connector for the uvch per side, good luck bud
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 09-09-2013, 08:03 AM Thread Starter
forttravis's Avatar
would it be a pain in the *** to put the new style block in or do i have to get all different computers
post #4 of 6 Old 09-09-2013, 08:39 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Not sure about the ECM but I know the early 99 and some 2000 had forged rods! Best 7.3 IMO is the 2000 since it has the forged rods and 17* HPOP. The ECM for a 99+ would be programmed for a 4R100 unless you have a manual trans. Blocks should be interchangeable though...
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 6 Old 09-09-2013, 08:44 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Just swap the injectors, turbo, up pipes, uvch, and you should be good to go, your computer will run that motor fine
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 6 Old 09-09-2013, 09:40 AM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
using a newer 99+ block you will need to use e fuel since the mechanical pump will not bolt to the motor.
you can always swap everything from your motor to the new block if you use it and use an e fuel set up
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
