Looking into getting my first truck - Ford Powerstroke Diesel Forum
post #1 of 25 Old 09-08-2013, 06:42 PM Thread Starter
Thumbs up Looking into getting my first truck
Names stephen, 18 year old kid getting into my first diesel. I already know basically what i want, but just have a few more questions before i get into a buy. Im looking for a CCSB or ECLB 4x4 7.3 TD. Powerstroke or IDI doesnt matter, just want a turbocharged and intercooled truck. My first question is which years for the IDI and PSD started the inercoolers, and which years are better than the others. for example, im told the 97 PSD was the best year for the obs 7.3s. Also, when i go to look at trucks is there anything 7.3 specific to look for before i commit?
any input is welcome, thanks guys.
stephenp95 is offline
post #2 of 25 Old 09-08-2013, 06:47 PM
jesilvas's Avatar
Quoted: 2 Post(s)
:ORGwelcome:
The SuperDuty trucks were intercooled. So 99+.
All Powerstrokes are turboed, but not all IDIs are turbod. Idr what years are what.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 25 Old 09-08-2013, 07:29 PM Thread Starter
Question
i see, is adding an intercooler to a OBS difficult? ( OBS Is up to 5k cheaper round me and IMO looks better.)
post #4 of 25 Old 09-08-2013, 09:28 PM
cheysays7.3's Avatar
In 94 three diesels were produced. One IDI, one IDI with turbo from factory, and the true "powerstroke" at 94.5. Check vins of that year to make sure. No OBS powerstrokes were intercooled. Go with manual if you expect to tow, unless you want to dump money on the tranny. Go with a 350 as well, they come with d60 straight axle as oppose to the d50 on the 250's. Make sure the truck is stable before modding. Buzz test, contribution, ect. I'd also change all fluids and start fresh.
Adding an intercooler is not too complicated. Add gauges to your list as well. I have pyro, boost, and transmission temp. I have an auto - trans temp isn't as important on a manual. Intake and downpipe are first on most lists, helps the truck breath.
1995 F250 7.3 ECLB - 6637, 3" MBRP downpipe, Autometer Pro Comp Ultra lite Boost pyro and trans gauges, Heavy Duty built trans, Proline FlatBed, and much more to come!
cheysays7.3 is offline
post #5 of 25 Old 09-08-2013, 10:33 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
adding an intercooler isn't the hard... If you do your homework every time I see and OBS truck it makes me miss my old 97 F350. Definitely a true work horse!
Oh and welcome to org cheysays7.3 also, where in Oregon are you from?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #6 of 25 Old 09-09-2013, 05:16 AM Thread Starter
Okay. Thanks guys. And i wouldnt be towing much very often. Would the difference in mpg between the 250 and 350 be signifigant?
post #7 of 25 Old 09-09-2013, 05:26 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It would be negligible, I get the same in my f250 as my f350 stock for stock, my differences are 2 feet of bed, 2 extra rear tires, and a front axle
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 25 Old 09-09-2013, 06:20 AM Thread Starter
Interesting. However i have no use for a dualie xD
post #9 of 25 Old 09-09-2013, 06:42 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I didnt either till I realized I wanted a long bed hauler, I'd much rather haul with my dually than any other truck I've had, much more stable, although my f250 ccsb (Cali model) had much more power compared to my f350
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 25 Old 09-09-2013, 07:17 AM
Quoted: 8 Post(s)
The difference between a f-250 and f-350 is stiffer springs. Not all f-350s are drw. But the 97 f-350 has the strongest front end available.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
