downpipe, heat wrap or not - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-08-2013, 06:46 PM Thread Starter
I am going to order a downpipe this week. going with the 2 piece diamond eye. I wanted some opinions on heat wrapping the upper section, because it's next to the evaporator, wiring, and firewall.
tony0713 is offline
post #2 of 10 Old 09-08-2013, 06:56 PM
gabegoforth's Avatar
I don't have anything. Go for it if you want. It's not necessary to my knowledge.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #3 of 10 Old 09-08-2013, 06:56 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
I did not on my 94 (it still had the factory stuff over the firewall and AC box). If I was going to do anything about it, I would probably opt to have the DP ceramic coated. Cheers!
Patrick Feeley is offline
post #4 of 10 Old 09-08-2013, 07:20 PM Thread Starter
does the wrap make rust start prematurely
tony0713 is offline
post #5 of 10 Old 09-08-2013, 07:46 PM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
Simply put, yes.
The heat wrap keeps the heat in but also traps moisture (not that a downpipe will stay wet for long). I've had headers wrapped up before and it's amazing stuff, but it takes its toll on the pipes.
I really like the idea of ceramic coating it if you're worried. Or run a ss downpipe.
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #6 of 10 Old 09-08-2013, 07:58 PM
Your probably better off putting more reflecting stuff on the firewall and stuff than the actual pipe by the sounds of it.
post #7 of 10 Old 09-08-2013, 08:13 PM
Quoted: 398 Post(s)
Garage
My folks had a 6.9 with the ATS turbo system on it. The DP was wrapped up on it for 15 years. It only got driven about 3000/year at most though.
post #8 of 10 Old 09-09-2013, 06:24 PM
dr.deere's Avatar
Quoted: 19 Post(s)
we wrapped the upper half of the downpipe on my 97. was it necessary probably not but I had the wrap on hand because we wrapped the up pipes.
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #9 of 10 Old 09-09-2013, 07:10 PM
Not necessary, but you can benefit from it. I know on my truck on longer trips in the summer, the passenger side floor can get warm. But not enough to cause damage of any sort. Its going to be a really tight fit to begin with. Most people have had to bend the seam of the firewall to get a downpipe to fit. So it could be a bit more work to allow for a couple layers of heat wrap.
Also something no one has addressed is it will be keeping heat in, and could result in higher EGT's. How much im not sure, but cooler is always better and not having it heat wrapped will allow the pipe to dissipate heat better. Air is a good insullater that will protect items close by.
If you must opt for something, I would say go with ceramic coating. But IMHO I feel the money could go better elsewhere for other upgrades that you can feel in the seat of your pants....
Jason
1997 F250 7.3L CCSB, DP tuner: drive thru, 60tow, 80e, 120, 140, Beans tymar, DP to 4" open exhaust, hughes tranny w/deep pan, 1.0 housing, gutted EBPV, new uppipes!, PMF 3.5" RSK, V and F code SD springs, 35x12.50 toyo m/t's on 18x10 raceline renegades, HID's, 7000#
Originally Posted by Red Steagall
...but then what does a man need besides a good horse, fresh air, plenty to eat, and good friends? Everything else seems like a waste...
azbroncbuster is offline
post #10 of 10 Old 09-10-2013, 05:37 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
I just used the wrap from the factory downpipe, cut it in half, and strapped it as far as I can, especially along the transmission, my floor does not get that hot.
dirtcrew51m is offline
