Carrier bearing Removal/Install - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-08-2013, 08:21 AM Thread Starter
So im looking to tackle my carrier bearing on my 1997 f-250 ex cab long bed 7.3l 4x4 on monday and decided to look for some tips. I am pretty mechanically inclined but haven't really messed with drive shafts too much. I hear the system is balanced and you have to mark things. What exactly do you mark? Pictures would help! If someone knows of a thread that is step by step that would be awesome as well. Thanks!
powerstroke814 is offline
post #2 of 5 Old 09-08-2013, 12:47 PM
95redrifle's Avatar
Quoted: 4 Post(s)
When i did the one on my last truck i didnt mark anything or balance it and i had no problems with it. Youll need new clamp rings for the boot on the driveshaft. The new bearing needs to be pressed on. or what i did was take a hammer and big flat head and slowly work your way around it. If you have a big enough freezer put the driveshaft in there and heat the bearing up a little to help it slide on
Sent from AutoGuide.com App
tony
1997 F250 4.10's
D60 swap/mag-hytec rear diff. cover
ts 6 pos./Autometers
melling LPOP/T-500 HPOP
D66 w/1.0 housing and WW2
160/80 rosewoods/bellowed up-pipes
08 king ranch seats/center console
south bend clutch
95redrifle is offline
post #3 of 5 Old 09-08-2013, 01:17 PM
ZMANN's Avatar
Quoted: 1914 Post(s)
I haven't done mine yet but even though I do all my own work I will likley drop off the shaft and have a full service and balance done
saving me a few hours of cussing
if you DIY a lot of folks run zipties in place of the steel 1 use l OEM clamp
I don't see a reason not to mark the locations since it's free and will save second guessing if you pick up a new vibration
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #4 of 5 Old 09-08-2013, 03:03 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
I'd mark the slip yoke so that the same splines meet up so the driveshaft goes back the same way it came out. Change the universals while I are there
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #5 of 5 Old 09-08-2013, 08:56 PM
Woodturner Nate's Avatar
Quoted: 2 Post(s)
I just did this on my '96. Just get a shop to press off the old bearing when you get the new one pressed on. It was the same charge no matter whether you already had the bearing off when you had to put the new one on. Save yourself the headache. I didn't mark it and have no problems with vibration or anything. Do yourself a favor though and get U-joints with grease fittings. I talked to a couple mechanics, and if you go through water or mud regularly, they're bound to get water in there eventually. Keep 'em greasy.
2007 F350 King Ranch CCLB 4x4
WVO conversion in planning
RIP 1996 F250 eclb, 4x4, 7.3L PS
Viair 444C/6g air tank on frame, Hadley air horn, Hella auxiliary reverse light, DIY WVO conversion; Efuel, dual FuelLab FPR's, 90g RDS tank, aluminum tube-in-heater hose, hotfox heated fuel pickup, copper coil-wrapped filter, 40-plate FPHE, auxiliary coolant pump, 2000lb winch-crane bolted to the frame. Ranch hand front bumper. Big winch.
Woodturner Nate is offline
