tps question - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-06-2013, 08:16 AM Thread Starter
tps question
what is the difference between a tps sensor and a app sensor. my truck keeps throwing a p0221 code. will this also cause the trans to shift weird?
1997 F250 7.3L XLT Auto 4x4 std. cab
190k
Hypertech maxenergy stage 1
dyi tymar intake
S.S downpipe to 5" stacks
glow shift gauges
pro comp xtreme alloy rims
Nitto Terra Grapplers 285/75/16
fpr mod
kcm s.s. hpx line
fordF250 is offline
post #2 of 10 Old 09-06-2013, 08:26 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
The TPS/PPS/APS (Throttle Position Switch [not found in diesels, we do not have "throttles"]/ Pedal Position Switch/ Accelerator Position Switch) is a variable resistor (think dimmer switch) that tells the PCM how hard you want to accelerate (PCM calculates against the VSS and tranny currently selected gear). The AP switch works with the IVS or Idle Validation Switch. This is a separate switch on the pedal assembly that tells the PCM to override the TPS and enter "Idle Logic". P0221 is usually a sign that the IVS is starting to malfunction and is either not clicking open quick enough for the TPS as you come off idle or that the IVS is closing while you are driving off idle. If this sets a hard fault to the PCM you will be stuck in idle logic until you replace the IVS.
Test the IVS by hooking a meter to it in OHMs setting (truck off) and push the go pedal in and out. A clean signal from the switch will show OFL->.01->OFL->.01 ONLY! Any wavering/jumping in the signal generally means the switch is faulty.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 10 Old 09-06-2013, 09:21 AM Thread Starter
if that is the case then how do I go about fixing it?
190k
dyi tymar intake
glow shift gauges
fpr mod
kcm s.s. hpx line
fordF250 is offline
post #4 of 10 Old 09-06-2013, 09:27 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Welp, the **** answer is that you have to go back to Ford and buy a whole new pedal as the switches on the pedal are Ford labeled "non-adjustable/non-repairable". Dorman sells the resistor and switch separately but the the quality is hit or miss. That just leaves going to a pick-and-pull and harvesting one out of a dead diesel.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #5 of 10 Old 09-06-2013, 09:32 AM Thread Starter
i did the ohms test and when the pedal was pushed in it was readin 0.00 and when left out it was every where
190k
dyi tymar intake
glow shift gauges
fpr mod
kcm s.s. hpx line
fordF250 is offline
post #6 of 10 Old 09-06-2013, 09:34 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
k. Your meter reads much lower than mine to show .00 to my .01. IVS is done. Get a new one soon.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #7 of 10 Old 09-06-2013, 11:26 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
For us, the TPS/APP/PPS sensors are the same thing. You can always try spraying the IVS with some Electrical Contact Cleaner. I would do it with the connector unplugged and cyle it a bunch. There was a post on one of the forums on the IVS being (somewhat) available. I'll see if I can find it. Cheers!
Thanks to "Desert Rancher" for the following info:
This is the Manufacturer and P/N for the Ford IVS. It is the actual part made for Ford.
Look here: http://www.onlinecomponents.com/cutl...tml?p=11071279
Cutler Hammer/Eaton SS22BW32-330Y
Patrick Feeley is offline
post #8 of 10 Old 09-06-2013, 11:30 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
The stock Eaton number is SS22BW32-330Y but hard pressed to have someone with it in stock.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #9 of 10 Old 09-06-2013, 05:03 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
My 95 has the sensor and switch that can be replaced, also check NAPA for the complete petal assembly, Dorman makes them, I sold a couple for the 2000's super duty, cant remember what years though. Or try ebay.
dirtcrew51m is offline
post #10 of 10 Old 09-07-2013, 01:09 PM Thread Starter
Thanks for the help guys. I found a pedal out of a wrecked psd. so hopefully when it shows up and i put it in it fixes the problem. Been having problems with it since the garage changed the app sensor a year ago.
190k
dyi tymar intake
glow shift gauges
fpr mod
kcm s.s. hpx line
fordF250 is offline
