Bad O-Rings - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-26-2008, 06:34 PM Thread Starter
Bad O-Rings
Just got through having to change all the O-Rings on the injectors after only 15,000 miles since rebuild. I made the mistake of using the ones that came with the fel-pro gasket set.
The second o-ring looked like some one had burned half of the o-ring. oil had eaten half of the o-ring. Was told that you can't use the felpro because they are crap. Has any one else had this problem???
Copyman is offline
post #2 of 2 Old 04-27-2008, 01:06 AM
Rantheman's Avatar
Felpro is my #1 choice for all rebuilds I do except I have bever used injector o-rings from them so I could believe it.
1995 Ford F250 4X4 Sup cap Long bed off white
7.3L Powerstroke, 5 speed manual
Mods Stancor GPR, Diamond eye 3" DP, Diamond Eye 4" Exhaust, AFE Stage II Intake,3" plenum setup,Swamps IDM,Eletric Fuel System,Adrenaline HPOP,stage I sticks, ts 6 pos,
Banks 5" Tips, Leveling Kit,Dana 60 Swap, AutoMeter Boost, Pyro, Fuel Pressure
30% Windows,
Rantheman is offline
