97 Injectors - Ford Powerstroke Diesel Forum
Old 04-25-2008, 10:45 AM
97 Injectors
I have a 97 DRW ,auto cab and chassis. Its always had a dump body on it. I recently bought it and am going through it to use as a work truck. I am new to the site and find myself here about everyday learning all I can. And thats alot. I plan on air filter,DP and straight pipe mods right away. Then go from there as the money allows. I have read about the differant injectors, size, splitshot. How do I determine what my engine has. 97 seems to be a year of evolution? Should I take my VIN# to a dealer and have them tell me? I am not sure of any mods before I got it so that might not work. I have maint sheets for the last seven years ( was a company owned truck) and they dont list any mods. It does show injector replacement. But they didnt change them all. Why I dont know. It has 139,000 mi. on it. Also what is the stock rear end. Dana 50,60 ? or corporate? Any help would be great.
Old 04-25-2008, 10:52 AM
Rosewood DIY injectors are a good choice, you can do them yourself or send them to him. If you want to upgrade injectors to stage I or II, I would DEFINATELY put an intercooler on your truck and gauges.
I dont remember exactly whats different about our 97 injectors... so heres a bump to the top for someone who is positive about them.
Old 04-25-2008, 05:21 PM
I think the CA model trucks had split shot injectors but correct me if im wrong, cant tell you how to tell if yours is a CA model though.
Old 04-25-2008, 07:04 PM
I found the information on the rearend, FORD 10.25 I think. 4.10 gears. When you say "CA" you mean California correct? I read that somewhere also. I am in NH, I should run the vin at the dealer. Thanks for the help
Old 04-27-2008, 07:21 AM
Calif trucks had 120cc split shots (AB CODE) 49 state had single shots 90cc AA. When you raise the hood there should be a sticker that says meets calif standers.
Old 04-27-2008, 11:09 AM
Send a message via AIM to PSDfreak
Couple quick and easy ways to tell:
1) Check passenger side valve cover sticker...if its Blue, its a CA model truck truck Splits
2) You can also check the lift pump in the valley (under turbo)...If there is a black disk with "Bosch" on it hanging off the back of the pump, thats a pulse dampener for splits meaning it would be a CA truck.
Old 04-27-2008, 08:20 PM
Thanks men, very helpful
