Well i figured out my fuel pump is dying and through extensive process of elimination why my truck died and wont start so i suppose its time to go to e-fuel. I read undercover7_3s write up for e-fuel for $200 or less but it was lacking the in your face details that i need. Basically i want to get a SD pump and thats about all know.
My questions are:
Sorry if this seems unreasonable but living at an apartment and wanting to get it done asap kinda limits me from extreme customization
My questions are:
- Where do all the lines go i have never really messed with the fuel system before so im sorry if im ignorant. Theres the 2 on top of the fuel pump with the blue hoses, the one on the bottom of the fuel pump with the single blue hose, the one on the right side with the tiny 1"-2" black hose, then theres the 2 that come off the front of the fpr, then finally the 2 that come out of the banjo bolt.
- Where do all of these lines go and do i still need them all with e-fuel?
- What exactly does the fpr do in lame-mans terms and what specifications do i need for one?
- What is the point of the banjo bolt and why can it just be a plain T-fitting?
- How does the fuel flow from beginning to the end(i.e. tank to injectors). What kind of lines and fittings should i use for ease of installation because i dont have any fancy tube bending tools so i want to leave as much stock as i can, basically just tapping into existing fittings.
- How does the dual tank selector come into play im assuming you tap into the line after that so theres no messing with that
