What maintenance should I do while the motor is out? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-13-2013, 07:09 PM Thread Starter
I've acquired a 1997 E350 shuttle van with a 7.3L diesel and E4OD auto. I plan on using the motor and tranny in a repower job. The engine has 360,000 on it, but pretty much no blowby and starts up pretty quick with a little white smoke at cold start. While the engine is out and on a stand I plan on replacing the glow plugs. It's going into a pretty tight engine compartment (I'm not sure if it will fit yet), so what else should I consider doing while everything is accessible? Has anyone tried to replace the output shaft on an e4od inorder to add 4wd?
B.Reilly01 is offline
post #2 of 16 Old 07-13-2013, 07:20 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Go ahead and do a rebuild on the fuel bowl unless your planning e fuel, and also injector o rings and pedistol too
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 16 Old 07-13-2013, 07:33 PM Thread Starter
I do intend on doing e-fuel, and I'll add pedestal and injector O-Rings
post #4 of 16 Old 07-13-2013, 07:35 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Or you could do a van pedistol and delete the pedistol ebpv
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 16 Old 07-13-2013, 07:46 PM Thread Starter
It's an e350 van chassis, would it have a EBPV? How can I tell?
post #6 of 16 Old 07-13-2013, 08:08 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Ohh my bad, I evidently didnt read it enough again lol, your fine then, there are slight differences in van motors and truck ones, not sure on all of them tho
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 16 Old 07-13-2013, 09:49 PM
drive one's Avatar
if you have the time, space, and money i would do a reseal. wouldnt want to get it all installed to find out a rear main or oil pan gasket blows a week later.
then again im a sucker for punishment and love knowing it wont go on me
drive one is offline
post #8 of 16 Old 07-14-2013, 07:03 AM
rolsmojave3's Avatar
I would definitely roll some new main and rod bearings in it. I did mine with 250k on the engine and they were shot! $170 and a little time, but the peace of mind is priceless. I also replaced the IPR when I had my engine out. Pull the LPOP and see if it's looking good yet. If its going into a tight space I would also reseal the oil cooler, replace UVCH (so when/if it shorts out you don't have to fight getting the valve covers off.
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #9 of 16 Old 07-14-2013, 08:36 PM
Gaius's Avatar
Quoted: 41 Post(s)
I would do uppipes, and all o-rings. From the turbo to the head plugs. Also rebuild the oil cooler. The fuel bowl hoses are easy to do in an engine bay.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #10 of 16 Old 07-15-2013, 06:37 AM Thread Starter
I think I'll definitely rebuild the oil cooler, that will be completely inaccessible in the new engine bay (Right up against the frame rail). I'll look at the uppipes, but they looked really good from the doghouse. Everything above the manifolds should be fairly easy to access in the new engine bay, so I'm mostly concerned with things that fail on the bottom half of the engine. I'm on the fence about rolling in new bearings, since it's not knocking, and I'm not doing rings, so it's only a half of a half assed rebuild. My understanding was that rings would probably present a problem before rod/main bearings.
What are the problems typically associated with the fuel bowl? Initially I just intended on running an electric lift pump into the stock fuel bowl, but I see most/all E-Fuel conversions include replacing/removing the stock fuel bowl.
