Zf5 swap questions (wiring/PCM) - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-13-2013, 01:38 PM Thread Starter
I have a 97 psd crew auto , I've had 2 other obs psd. 1 5speed and 1 auto. I was never satisfied with my auto even after having rebuilt. I've found a 96 psd 5 speed that is cheap enough I could use for a donor truck. I'm wondering if the 96/97 wiring harness and PCM are compatible , because was reading in another post that the connectors and pinouts are different throughout the years. I also have read you can keep the auto PCM and put the auto mlps in neutral, but then how do I get my reverse lights to work?
born2ride14 is offline
post #2 of 2 Old 07-13-2013, 02:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
With a switch
But harness is the same unless one of them is a California model, just strip the stick shift of everything but also keep in mine you will need to lengthen the driveshaft since the f250 is obviously not a CClb that your getting the parts from
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
