E99 spyder indetification - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-12-2013, 11:09 AM Thread Starter
95f350powerstroke*'s Avatar
What do I need to look for to make sure I'm getting an e99 spyder?
1995 F-350 Reg. 4x4 7.3, TDP chip with TW tunes, gauges, DIY intake 5" turbo back
95f350powerstroke* is offline
post #2 of 9 Old 07-12-2013, 11:16 AM
Patrick Feeley's Avatar
Quoted: 10 Post(s)
The one of the things will be that it will have 2-3/8" outlets to the intakes (not 3"). Look down about 3 pictures in this post: stock turbo? - Ford Truck Enthusiasts Forums
Cheers!
Patrick Feeley is offline
post #3 of 9 Old 07-12-2013, 11:45 AM Thread Starter
Awesome. Do you have any idea of what type of ic pipes and ic I need to use?
post #4 of 9 Old 07-12-2013, 11:49 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I've used an all aluminum ic from a 7.3, and plastic ended one from a 6.0, pipes have to be custom bent for specific needs tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 9 Old 07-12-2013, 12:07 PM Thread Starter
Where can I get pipes?
post #6 of 9 Old 07-12-2013, 12:14 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
how good are you with a welder?
banks sells pipes (i believe they are built to order ie not in stock)
chris lahmon sells all aluminum custom pipes his email is smokin-69@msn.com he may or may not be in the country at the moment.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #7 of 9 Old 07-12-2013, 12:37 PM Thread Starter
I'm not to shabby. I welded up a new radiator mount. The entire front piece. Cut the old if and dabbed up a new brace. How much do Chris's pipes run?
post #8 of 9 Old 07-12-2013, 12:55 PM
the baconator
Quoted: 141 Post(s)
chris used to charge 200 for pipes and clamps. don;t know what the current price is.
if you can weld you can make your own out of 3" pipe
post #9 of 9 Old 07-13-2013, 09:28 PM
Chris charged me 225 shipped on June 26 for the pipes, cant seem to get a hold of him now.
Ol' Blue 7.3 is offline
