My truck is not happy!!! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-12-2013, 06:18 AM Thread Starter
toad's Avatar
Quoted: 16 Post(s)
Yesterday I got in my truck, fired it up and happened to notice white smoke out the tailpipe. I popped the hood and the coolant bucket was empty. I checked the oil and it had a fair amount of metal sparklies in it. Oil was not milky. I filled the coolant bucket it took a gallon and half. So were is the coolant going? With the research that I have done it is either injector cups or head gaskets. What about the oil? That has me really scared.
1996 F250 crew cab. Hypermax intercooler, Gearhead tunes, 4" exhaust, 6637 intake, Autometer gauges, Dana 60, 6.0 cooling fan, Built e40d, Firestone airbags, Full Force stage ones more to come. SOLD
2003 7.3 F250 Lariat. Mostly stock.
toad is offline
post #2 of 6 Old 07-12-2013, 06:50 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Noticed a drip anywhere? Is the inner fender under the degas bottle wet?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 07-12-2013, 07:25 AM Thread Starter
toad's Avatar
Quoted: 16 Post(s)
nope no drips
toad is offline
post #4 of 6 Old 07-12-2013, 08:50 AM
Quoted: 48 Post(s)
Is it smoke in the exhaust or steam? If it's steam, that would explain the coolant loss.
See if you can get some of that metallic-looking oil into a small glass or plastic jar or vial. Then put a magnet up next to it. That will at least tell you whether it's iron or aluminum (or some other non-ferrous metal) suspended in it.
madpogue is offline
post #5 of 6 Old 07-12-2013, 09:54 AM Thread Starter
toad's Avatar
Quoted: 16 Post(s)
Yea it looks like steam. I wont do anything with it till tomorrow. I need to get on the Obama plan. Let everybody else work for me
toad is offline
post #6 of 6 Old 07-13-2013, 12:27 PM Thread Starter
toad's Avatar
Quoted: 16 Post(s)
So last night at about 6pm I pressured up the cooling system with a manual tester. Set the psi at 15 left for the night. Just barely checked it and it has only dropped 2.5 psi. I would think that if I had a bad injector cup is should drop faster than that. Any ideas
toad is offline
