clutch issues - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-11-2013, 12:23 PM Thread Starter
Quoted: 4 Post(s)
clutch issues
I have a 97 f250 7.3 powerstroke with a power programmer and exhaust. So i already know about the plastic clutch pedal bushings that go bad and mine is still a little loose but the slave cylinder by the trans is loose?? Is it supposed to be loose or what? does the clip that holds it on go bad?? I am having trouble getting it into gear and i am going to do the heim joint mod for the push rod. o and when the truck is at idle it makes a pretty bad knocking noise and when i push the clutch in it go's away is that the release bearing for the clutch? can that be part of the issues? I already blead the clutch but it did not help any thing. sorry for all the long questions
mikemalo is offline
post #2 of 6 Old 07-11-2013, 01:17 PM
Quoted: 58 Post(s)
No, the slave should be tight against the flange on the tranny. Never heard of that clip failing, but it's always possible. Also look very closely around there; I have heard of that part of the tranny case breaking.
Either that, or your clutch fork is bent, and therefore there's no "tension" in the whole setup. This would also explain the noise. Release bearing out of place is another possibility.
Are you on the original clutch and dumb-mass.... er.... dual-mass flywheel?
madpogue is offline
post #3 of 6 Old 07-11-2013, 05:19 PM Thread Starter
Quoted: 4 Post(s)
a other guy told me it could be the dual mass flywheel coming apart :0 that is causing that noise. also nothing seems to be broken around where the slave cylinder nether the shift fork seems to be bent. I cloked the arm forward for the clutch pedal and it broke the dam clutch push rod idk what happened i tested every thing before i tightened every thing ind it got rid of all the play in the pedal. so i am buying a new slave/master cylinder and hopefully it fixes every thing. still got to check out the flywheel
mikemalo is offline
post #4 of 6 Old 07-11-2013, 06:39 PM
Quoted: 58 Post(s)
Yup, that's diesel_brad, veteran of many truck forums. Dual-mass flywheel check - remove the flywheel inspection cover and try to move the flywheel by hand. If it moves several degrees, the flywheel is about to let go. If it lets go while underway, esp. at high speed, the jettisoning parts can grenade through the tranny case.
madpogue is offline
post #5 of 6 Old 07-12-2013, 10:14 AM Thread Starter
Quoted: 4 Post(s)
OK so i took off the inspection cover and nuthing moved at all!
mikemalo is offline
post #6 of 6 Old 07-12-2013, 05:19 PM
It would be must help you to remove it as you will must feel the difference while you are driving it up to the mark.
Brady1121 is offline
