Zf5 and transfer case fluid. - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-11-2013, 06:33 AM Thread Starter
Will Mobil Atf d/m trans fluid work in this trans and transfer case
Coreyroberts is offline
post #2 of 11 Old 07-11-2013, 07:10 AM
Quoted: 50 Post(s)
Should be fine in the T-case. Tranny requires synthetic ATF.
madpogue is offline
post #3 of 11 Old 07-11-2013, 07:32 AM Thread Starter
How many quarts goes in each
post #4 of 11 Old 07-11-2013, 07:41 AM
Quoted: 50 Post(s)
Something like 3.5 in the tranny. You basically fill it to the bottom of the fill plug. Some guys overfill it by pouring some in through the top (remove the shifter), to quiet the gear rollover noise. Then I've also heard that that's not good, that it puts excess pressure on some seals or something. I had only a little bit left over from a gallon jug when I did mine, and that was just using the fill plug, not overfilling it.
I forget how much in the t-case. Two or three maybe. The t-case has two fill plugs. You fill it up to the bottom of the lower fill plug for "normal" operation. If the t-case has a power take-off and you happen to use it, you're supposed to fill it to the bottom of the upper fill plug.
madpogue is offline
post #5 of 11 Old 07-11-2013, 01:48 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
i disagree you fill it to the bottom of the top plug (the fill) for normal use
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #6 of 11 Old 07-11-2013, 01:55 PM
Quoted: 50 Post(s)
There are two fill plugs, separate from the drain plug. The owner's manual states that you fill to the bottom of the lower fill plug for normal use, and to the bottom of the upper fill plug for PTO use.
madpogue is offline
post #7 of 11 Old 07-11-2013, 02:22 PM
dr.deere's Avatar
Quoted: 19 Post(s)
Must only be on some cases because I've had to rebuild mine(no pto covers) and only have one fill plug
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #8 of 11 Old 07-11-2013, 04:03 PM
the baconator
Quoted: 146 Post(s)
mine too. who knew.
i wonder is there is a different between the 1356 and the 4407 cases
post #9 of 11 Old 07-11-2013, 07:52 PM
Quoted: 50 Post(s)
Some (maybe all?) 1356 t-cases installed in F350 trucks have a pto cover on the right side of the front cover half. These t-cases also have an upper fill plug in the front cover, between the shifter input and the front driveshaft output. The non-PTO 1356s don't have that plug. No idea about the 4407s.
madpogue is offline
post #10 of 11 Old 07-12-2013, 04:54 AM
the baconator
Quoted: 146 Post(s)
now we know. and i believe that the PTO transfer case was a rare beast. i have only seen one
