Help identifying sensors a 94 7.3L Powerstroke can run without - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-10-2013, 03:54 PM Thread Starter
marine7.3's Avatar
Exclamation Help identifying sensors a 94 7.3L Powerstroke can run without
Can someone list the sensors on a 94 7.3L Powerstorke and which it can run without?
Also would I need someone to hook it up to a computer to disable them?
I currently have a 7.3 IDI in my boat and have the opportunity of swapping it for the Powerstroke.
Thanks all
marine7.3 is offline
post #2 of 8 Old 07-10-2013, 04:18 PM
Quoted: 82 Post(s)
Feedback Score: 4 reviews
If you want to run the powerstroke in your boat you will be much better off to get the marine ecm and wiring harness.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 8 Old 07-10-2013, 05:12 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Honestly it needs all the sensors Kause the PCM reads those perameters to let it know what to do, it's a drive by wire system unlike the idi version where it's almost like a carb'd truck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 8 Old 07-11-2013, 04:55 AM
svranger25's Avatar
We need some pics of this powerstroked boat, for information purposes of course....
-Brandon-
1996 F 350 7.3L CCLB
6637 Intake; Banks: Intercooler, Up Pipes, Turbo; PHP Phoenix
4" down-pipe, cat delete,muffler delete, 4" turbo back exhaust
Sky Jacker Suspension, Limo Tint, Cobra Classic 29 LTD,
Stage 2 TC, improved internals
Loudest, Proudest member of the Fightin' Texas Aggie Class of 2015!
svranger25 is offline
post #5 of 8 Old 07-11-2013, 05:24 AM Thread Starter
marine7.3's Avatar
Brandon
Its still IDI but I have an early 7.3 powerstroke I want to put in it.
These are some videos & images of the boat. Four years in the making.
post #6 of 8 Old 07-11-2013, 05:48 AM
Quoted: 82 Post(s)
I've worked on several boats over the years with Idi and powerstroke engines and can tell you that the Idi's where less problematic in the marine environment. A Idi engine in good condition with turbo and marine injectors with a few little tweaks does a excellent job.
Jack
322000 miles
post #7 of 8 Old 07-11-2013, 06:06 AM Thread Starter
marine7.3's Avatar
I agree with you Jack.
I do enjoy the simplicity of my IDI and have an authentic IDI marine turbo for it. However the turboed engine I purchased is seized. I have read that turboed IDI has anodized pistons, bigger wrist pins, different injectors and the list goes on.
Would I be able to slap the trubo on my running IDI? Are there master rebuild kits for the turboed IDI?
Do you know the part number for marine injectors?
post #8 of 8 Old 07-11-2013, 06:24 AM
Quoted: 82 Post(s)
Yes the factory 7.3 turbo engine did have the upgrades that you mentioned. I have run 15 lbs of boost on a naturally aspirated (from the factory) engine with no problems so yes on installing the turbo on your running engine. I don't remember the marine injector part numbers but any injection shop or international dealer should be able to help you. There are rebuild kits available but don't buy anything until you tear down the seized engine to find out if the cylinders can or need to be bored oversize.
Jack
322000 miles
