Dipstick Flange Repair - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-10-2013, 07:37 AM Thread Starter
svranger25's Avatar
Hey guys, I have found the inner o ring from fordparts.com anybody know a part number for the outer gasket between the pan and the nut. Anyone know the cost of ford grey rtv, I might pick up that, although I wont have a day of drying time, any other good sealants? Also part number for the o ring on the dipstick, I think that about covers the repair right?
-Brandon-
1996 F 350 7.3L CCLB
6637 Intake; Banks: Intercooler, Up Pipes, Turbo; PHP Phoenix
4" down-pipe, cat delete,muffler delete, 4" turbo back exhaust
Sky Jacker Suspension, Limo Tint, Cobra Classic 29 LTD,
Stage 2 TC, improved internals
Loudest, Proudest member of the Fightin' Texas Aggie Class of 2015!
svranger25 is offline
post #2 of 11 Old 07-10-2013, 11:34 AM
Patrick Feeley's Avatar
Quoted: 10 Post(s)
How about this: Oil Level Gauge Adapter Repair Kit for 1994 - 2003
Cheers!
Patrick Feeley is offline
post #3 of 11 Old 07-10-2013, 12:34 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Not sure on part numbers but no o ring on outside of pan, just the inside, and the kit for it has red locktite with it, o ring for inside the pan was like $7.50 at my local dealer
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 11 Old 07-10-2013, 12:40 PM Thread Starter
svranger25's Avatar
ya I know about the kit but 50 bucks for something I have to wait to be shipped and something I could spend 15 on instead of fifty. you think the inside o ring is sufficient to get it fixed?
-Brandon-
post #5 of 11 Old 07-10-2013, 01:05 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I have under $20 in my fix, got the flange o ring at ford for $7.50, the dipstick o ring (I bout 2 Kause they were not as wide as one removed) $0.75, red loctite $3.67, and galley brush $2.49, I also used some string I had laying around and black permatex once I put it together just in case
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 11 Old 07-11-2013, 05:58 AM Thread Starter
svranger25's Avatar
ya that's the way i'm seeing it, plans are for tomorrow to git-r-done, I still need to pick up dipstick o rings though
-Brandon-
post #7 of 11 Old 07-11-2013, 06:59 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
If you unbolt the dip stick and just pull it out the o ring is very small and I got 2 to replace it at o'reilly auto since they didnt have the wide one like removed
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 11 Old 10-25-2014, 11:56 AM Thread Starter
svranger25's Avatar
So i'm going to bring this back from the dead cause i actually started doing this repair today, oops, but when i pulled the old o ring out its nothing like the new one, pic attached, is the old one just swollen?
Name:	2014-10-25 13.46.54.jpg
-Brandon-
post #9 of 11 Old 10-26-2014, 07:29 PM
Yup. It's just swollen. That's a very typical look for these orings after sitting in oil for many years.
Good luck!
williameub is offline
post #10 of 11 Old 10-28-2014, 12:24 PM
sgt dave's Avatar
Quoted: 3 Post(s)
I bought the repair kit from strictly diesel 2 months ago and install was fairly easy and well worth the $300.00 price.
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
