IN Need of a Good Block - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-09-2013, 08:55 PM Thread Starter
Articcatzl440's Avatar
Well trying to rebuild my 7.3 and have found out that my block is not salvageable do to the amount of wear 40 over will not clean it. so im in search of a good block. Any help is greatly appreciated.
2005 F350 CC LB 6.0 Lariat,
Goodyear Wrangler Silent Armor Tires,
RCD EGR Delete,
New oil cooler 65,500,
Cat ELC Coolant,
Updated turbo drain tube,
2004 Excursion 6.0 Eddie Bauer,
Cooper Discoverer AT3,
FireStone Rideright air helper springs,
EGR delete,
ARP Studs,
1994.5 F350 CC LB Powerstroke
305,000 and counting
ZF5 Speed
Cat ELC Coolant
6637 intake
solid flywheel
Rose Wood Stage 1.5
Diamond Eye 4 inch
Isspro Gauges
BFG 33/12.5/16.5
Articcatzl440 is offline
post #2 of 9 Old 07-09-2013, 10:21 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Where you located at? Honestly buying a whole truck as a rust bucket would be cheaper than trying to find a good engine
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 9 Old 07-09-2013, 11:06 PM Thread Starter
Im in bozeman MT and there isnt any rust buckets here we dont salt. everything seems to be worth gold here in the diesel world. there are two blocks in town that are shot and the guy wants 800 for them. and i have three blocks that arnt usable as well im not having much luck.
RCD EGR Delete,
Cat ELC Coolant,
EGR delete,
ARP Studs,
ZF5 Speed
Cat ELC Coolant
6637 intake
solid flywheel
Rose Wood Stage 1.5
Diamond Eye 4 inch
Isspro Gauges
BFG 33/12.5/16.5
post #4 of 9 Old 07-10-2013, 01:39 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Its funny. I just SCRAPPED a good engine because I couldnt get 400 for it. I guess it is all about location
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 9 Old 07-10-2013, 07:19 AM
superduty4x4's Avatar
I'm not real close by any means, but I have a 7.3L PSD long block I might part with. Mileage is around 230K and I have no idea what the compression numbers were or what the cylinders look like, it was in a truck I picked up cheap that had an engine bay fire. If you're interested let me know, I'm in Newport, WA 99156.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #6 of 9 Old 07-10-2013, 10:01 PM
JD3020's Avatar
Same here. May end up scrapping my old longblock soon. Compression ranges from 290-340, ran fine when i pulled it. Well slightly rough and smoke at start-up, but still fired right up and hauled *** day in and day out. I've had 0 interest on it so far.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #7 of 9 Old 07-11-2013, 06:52 AM
I wish some of you boys were closer, and I had more room...
post #8 of 9 Old 07-11-2013, 09:10 AM
Quoted: 82 Post(s)
Have you talked to a machine shop about sleeving the block? I've had it done on several engines and some engines where built that way.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #9 of 9 Old 07-11-2013, 10:18 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
I have a long block i could sell ya cheep but..... i live in MD
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
