Is turbo working??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-09-2013, 06:29 AM Thread Starter
Is turbo working???
Got a 97 7.3 psd. How do I check if my turbo is working? Haven't had the truck long but it seems sluggish and I can't hear any turbo winding. It's a big son of uh, super cab 8' box so I know it's pushing some weight, but I know just enough to think something ain't right. Could use any tips, thanks.
WorkDog is offline
post #2 of 6 Old 07-09-2013, 07:35 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Pull the intake off the turbo check for shaft play, sticking, and pitting on the impeller wheel
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 07-09-2013, 07:43 AM Thread Starter
Can I also check it when it's running to see if its even spinning? Sorry if these are stupid questions I'm a contractor not a mechanic.
WorkDog is offline
post #4 of 6 Old 07-09-2013, 07:50 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I wouldn't run it with no filter, that turbo will eat anything, but you could also have an exhaust leak pre turbo, look for soot on the firewall, and the exhaust manifolds, and where those connect to the up pipes and where up pipes connect to the turbo
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 6 Old 07-09-2013, 08:23 AM Thread Starter
I'll check. Also don't know when fuel filter and injectors were changed last. Keep ya posted, thanks.
WorkDog is offline
post #6 of 6 Old 07-09-2013, 11:35 AM
Quoted: 48 Post(s)
You don't really hear the turbo with a stock intake and exhaust. Get yourself an aftermarket 6637-based intake and a 3" round downpipe (and cat delete / straight pipe if you're inclined), and you'll start to hear her whine.
You could always hook up a scanner or AutoEnginuity and monitor MAP.
madpogue is offline
