Positive battery lead - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-05-2013, 08:07 PM Thread Starter
mkeith54's Avatar
Does anyone have a factory power cable out of the truck that they could take photos of and provide measurements? I plan on building a new one for my truck, but I don't want the truck down for an extended period while I order the parts from McMaster Carr. I can track the wire from the left battery to the right and then it drops down to the front of the motor and I lose sight of where it goes. BTW If you have the negative wires as well that info would be appreciated as well.
Mike Keith
New Florence Mo
1996 F-250 ECSB, 6-pos/ts chip/ Tymar intake
Pyro, boost, and tranny gauges
mkeith54 is offline
post #2 of 5 Old 07-06-2013, 05:22 AM
dr.deere's Avatar
Quoted: 19 Post(s)
When the positive goes in front if the
Motor it runs on top of the cross member to the starter. I know cuz ic changed that cable on the 94
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #3 of 5 Old 07-06-2013, 09:16 PM
Quoted: 82 Post(s)
Feedback Score: 4 reviews
Could just get this NAPA AUTO PARTS
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #4 of 5 Old 07-07-2013, 07:45 AM
dr.deere's Avatar
Quoted: 19 Post(s)
I would recommend getting a ford part not the napa. I out the napa on my 94 the cable is too long in my opinion I have more hanging around the the original and more than I would like
dr.deere is offline
post #5 of 5 Old 07-07-2013, 09:17 AM
Custom Battery Cables F350 cables
Custom Battery Cables are heavier gauge cable and you have the capability to use military battery clamps so you only have to replace the clamps down the line. A little modification to the starter cable the other day when I replaced the stock starter with a SD gear reduction starter.
RM20 is offline
