White smoke at idle - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-05-2013, 05:54 PM Thread Starter
Made In America
Guardian29's Avatar
White smoke at idle
Hey guys just bought my first OBS and I love it! Mods done are BTS tranns and HPOPs, Hypermax turbo and stage 2 injectors, FASS fuel pump, DP tuner, ARP head studs and BANKS intercooler. ITs not a lot, but it deffinately it pushing out a fair amount of white smoke at idle. So is this a bad thing or it that just because of the injectors and whatnot? Im thinking maybe its because he has a K&N style intake which will soon be changed out for a 6637. Idk just curious if its something that needs to be investigated. Thanks!
PHIL
'12 F250 CCSB, 35's, MiniMaxx, Deleted (Currently OOC)
'97 F350 CCLB, 6" Skyjacker w/ BDS and 35s, BTS tranny and HPOPs, 4.10s, H2E and stage 2 injectors, FASS 150, Banks intercooler, ARP head studs, IDM mod, DP tuner, WARN hubs, 6637, rear airbags
Guardian29 is offline
post #2 of 13 Old 07-06-2013, 04:26 AM
dr.deere's Avatar
Quoted: 19 Post(s)
White smoke is either coolant or raw fuel. The k&n is not gonna make it smoke white. And I know what your thinking its could've dusted the turbo I don't buy it I've been running k&n on several vehicles for many thousands of miles and never damaged a turbo. If turbo was dusted it shouldn't smoke at tilde because your not building any boost it would be up in rpm where you would notice turbo problems
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #3 of 13 Old 07-06-2013, 06:19 AM
Quoted: 822 Post(s)
White smoke is anti freeze and smells kinda sweet maple syrup like. White/greyish smoke that smells like fuel is oil burning, black smoke is raw fuel.
Is your oil level or coolant tank going down over shorter periods of time? Is this happening only at startup cold or all the time? Need some more details to help u out.
Corey@CNCFAB is offline
post #4 of 13 Old 07-06-2013, 06:23 AM
clatterindiesel's Avatar
Take a look in coolant resovoir and a wiff of it too. Smell like varnish?
I live close to ocala and surrounding areas, so if anyone ever needs a hand with their truck....get a hold of me.
clatterindiesel is offline
post #5 of 13 Old 07-06-2013, 07:15 AM Thread Starter
Made In America
Guardian29's Avatar
Hey guys sorry suffering from a recent brain injury tryig my best here. The smoke is all the time, and gets worse as you turn the tuner up to its hot settings. Notsure on the smells im flying today away from the truck. When I accelerate and get on it turns to black normal like it should.
PHIL
post #6 of 13 Old 07-06-2013, 07:24 AM
gavol64's Avatar
I have a 2006 6.0l that smokes heavy until warm then no smoke . It's heaviest at idle and when you accelerate. It also jumps around sometimes at idle. Has all new injectors, high pressure oil pump, egr delete done and no programmer. It does use oil and has 199,000 miles. It doesn't use any coolant. I just pulled a large boat back from miami and nothing changed under stress. I'm so confused. No codes. Please help!!!
2003 F250 superduty Crew Cab 4x4 - 4" Rancho lift, Rancho 9 way adjustable shocks, CAT Delete, Royal Purple Synthetic Oil, Royal Purple Transmission and Differintial Fluid, Hypertech Transmission Pan and Differintial Cover, Edge CS Guages, EGT Probe, Dick Cepek 315x75x16, EGR Delete, Roll n Lock Bed Cover, MBRP 4" Turbo Back Exaust, Rev-X, 2005 Grill, Line X Bedliner.
gavol64 is offline
post #7 of 13 Old 07-06-2013, 07:31 AM Thread Starter
Made In America
Guardian29's Avatar
Thread jacker...?
PHIL
post #8 of 13 Old 07-06-2013, 07:32 AM
Quoted: 822 Post(s)
Gavol,
I suggest go through your Glow plug system and add some RevX. Also, 6.0 injectors like synthetic much better if your not using it already.
post #9 of 13 Old 07-06-2013, 07:42 AM
Quoted: 822 Post(s)
Since its all the time that pretty much rules out GP system. As you turn up the tuner I am going to say its oil burning. As your tune requires higher oil pressure it is probably leaking more past the O-rings. Typically its the outer O-rings but it is possible the inner O-rings are leaking too. Outer O-rings can be an easy DIY job if your mechanically inclined wrenching on cars, if its internal (not as common) then they pretty much need rebuilt or buy a new one.
When you get back have a buzz test and Cylinder Contribution Test done. That will lead you to the culprit without having to do them all.
post #10 of 13 Old 07-06-2013, 07:45 AM
Quoted: 822 Post(s)
Thread jacker...?
Ya, thread jacker, that's jacked up. Lol.
