New here with a common fuel leak! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-05-2013, 10:51 AM Thread Starter
woodtrucker's Avatar
New here! New to me 1995 PSD! Excited about having a diesel. Not so excited to get all the worn out stuff fixed on this thing. I have about $1200 to fix worn out steering components, a bad throw out bearing with sqeeky clutch, and fuel leak.
I have found the fuel leak and was wondering if anyone has had similar leaking characteristics. It appears that it only leaks when running. I cranked her up (runs absolutely great by the way) and started carefully looking for the leak.
I found the nearly hidden short blue hose about 1" long going from fuel pump to fuel bowl dripping right at the pipe clamped connection to the fuel pump. I plan to go home after work and try to get to the clamp and tighten it down more and see if that stops the leak. Just wondering if it could really be anything more than just a leak hose. It seems to drip about every three seconds. I don't see any other fuel spraying on engine like some folks seem to have. Great to be here!
woodtrucker is offline
post #2 of 4 Old 07-05-2013, 11:10 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Just remove the bowl and replace all 3 of those lines behind there, they are very prone to leaks and what not over age
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 07-05-2013, 11:12 AM
01Crewcab7.3's Avatar
They always give people problems which is why most opt for an e-fuel conversion/bowl delete.
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #4 of 4 Old 07-05-2013, 12:13 PM Thread Starter
will have to look into that!
