Want to get rid of pulling gears - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-05-2013, 08:36 AM Thread Starter
FeelDatPowerstroke's Avatar
I have a 94 Powerstroke 2 wheel drive regular cab and it has the low pulling gears in it I am a noob at diesels really only 16 this is my first truck but I think the gears come from the rear axle right so what is the best way to put a higher gear ratio so I can drive on the intersate in 5th gear at 70 lower than like 2300 rpms haha thanks
FeelDatPowerstroke is offline
post #2 of 2 Old 07-05-2013, 08:42 AM
01Crewcab7.3's Avatar
You probably have 4.10's. The only option you have is to switch to a set of 3.55's. In my personal opinion it is not worth the almost $1,000 to switch gears. I would either A) get a 10.25 out of a junkyard that has 3.55 gears and switch rear-ends or B) get a different car to commute with.
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
