need some help guys - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-05-2013, 04:56 AM Thread Starter
need some help guys
Ok so I got a 97 ext cab lb with an e4od and I went for a ride yesterday and all of a sudden the Speedo dropped to zero my odometer went blank or would start shifting funny and the od light would blink. I checked the number 8 fuse for the Speedo what else can I look for?
viggy924 is offline
post #2 of 7 Old 07-05-2013, 06:02 AM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 56 Post(s)
Feedback Score: 7 reviews
Chafed wires coming from the trans
God bless America, the Constitution and the Second Amendment.
powerstrokeshellback is offline
post #3 of 7 Old 07-05-2013, 09:04 AM Thread Starter
I'm not sure I spent 12 hours almost under the trick this week changing the flywheel cuz it cracked than ivdrove it all day long yesterday purred like a kitten in roids and ran better than the day I bought it and than I went to drive it later that night got halfway down the block and that's what happened. I will try today to get a chance to look at it is it anyway its something other than wires going to the trans under the truck
viggy924 is offline
post #4 of 7 Old 07-05-2013, 02:06 PM
Chop's Avatar
Check or replace your VSS sensor on the rear pumpkin and of course wires leading to it .
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #5 of 7 Old 07-05-2013, 09:06 PM Thread Starter
Well I went our there today to check it I started it up to move it into the shade .(the heat today sucked) and everrything was fine drive it around for an hour no problem so.idk what happened
viggy924 is offline
post #6 of 7 Old 07-06-2013, 02:51 AM
JSchuricht's Avatar
With your odometer going blank, it's not the VSS. Pull the cluster and check that everything is plugged in fully. The trans relies on the speed signal which it gets from the PSOM, the PSOM gets the signal from the VSS. What your seeing is the trans going into limp mode because it doesn't know what speed your going.
JSchuricht is offline
post #7 of 7 Old 07-08-2013, 10:34 AM Thread Starter
It's been perfectly fine since the day after it happened idk y or what but eventually I will look behind the dash and check all my wires I figured it wasn't the vss because like you said the odometer went blank but thank you for all your help and quick responses guys
viggy924 is offline
