Hard Start with Injectors? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-04-2013, 08:43 PM Thread Starter
Hey I have a couple questions about my 1995 7.3 powerstroke . It's having some hard start problem with injectors and have been looking into them and I'm curious if when I replace them if I should go back to stock or upgrade and go with stage 1 Injectors ? And if I did upgrade do I need to upgrade my fuel system to go with the stage one injectors ? I would appreciate any input anybody has ?
Sparchuleta is offline
post #2 of 2 Old 07-04-2013, 09:49 PM
01Crewcab7.3's Avatar
What do you mean by it is having a hard time starting with injectors? If you want to replace your injectors that is all good and fine but make sure that is the real reason for your hard starts before you blow $1,000+ on injectors that don't fix your problem.
To answer your other questions:
An electric fuel upgrade is a wise move with any injectors, stock or hybrids and anything in between.
Stage 1's are a good choice if you plan to keep as much of the truck stock as possible. You can run the stock HPOP if it is healthy, stock turbo, tranny etc. Full force diesel has a good price and warranty on the 160cc upgrade. You will need a custom tuned chip though to get the potential out of them. As well as intake, exhaust, and gauges if you do not already have them. Hope this helps.
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
