ford IH part interchange # - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-03-2013, 07:50 PM Thread Starter
Ranzan's Avatar
Quoted: 21 Post(s)
does anyone happen to have the part #s for the external and internal UVCH plugs...
I have the pin #s but not the plugs
Wes
2010 F350 CCLB 4x4 Lariat Sterling Grey
11 and up Console upgrade
Fully deleted DFC Long Block
2 1/2 levelling kit
1995 F350 CCLB XLT Stock for now....
1997 F350 CCLB 4x4 5 speed Tourmaline green
DDP Stage 1`s
08 Bucket console upgrade ( SOLD )
Ranzan is offline
post #2 of 2 Old 07-04-2013, 08:10 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Internal (meaning the plugs on the UVCHs) are not replaced, you just replace the UVCH. External plugs:
Valve Cover External Harness Repair Kits (contains 4 hard shells w/seals, w/o pins)
(Ford) F7TZ-14489-BA (94-96) w/o pins
(Ford) F7TZ-14489-AA (97) w/o pins
(International) 1830829C91 w/o pins
Female Pins, no wire lead (International) 1661875C1
Female Pins, with 6” wire lead (International) 2501055C1
Individual Wire/Pin seals (International) 1661872C1
Pigtail with 5 Wires and Connector (Performance Specialties) 99288
Cheers!
Patrick Feeley is offline
