Time estimate for injector removal? - Ford Powerstroke Diesel Forum
post #1 of 34 Old 07-03-2013, 08:45 PM Thread Starter
BR'sCrewCab's Avatar
Since I am off on Friday, I am considering pulling the injectors to ship them to Full Force to be converted to stage 1s. I was curious as to the time it takes to get them out?
96 F250 Crew Cab XLT
125,000 miles, Full Force Stage 1 Injectors, 4:10 rear, Dana 60 Swap, F350 Rear Lift Blocks, 325/60R18, 3" Down Pipe, 4" Exhaust, Tymar Intake, Aeoroforce Interceptor, DP Tuner (no start, stock, high idle, drive thru, 80 Eco, 60 Eco, 60 tow, 120 hp Race Tune), 7.3 Intercooler, 2.25 PMF RSK, V-Code Front Springs, B Code Rear Springs, Complete Alpine Audio System Upgrade, Tru-Cool Trans Cooler, Pro Comp 1069 18x9 Rims, John Woods Tow Master Transmission, Air Lift Air Bags
BR'sCrewCab is offline
post #2 of 34 Old 07-03-2013, 08:59 PM
toad's Avatar
Quoted: 16 Post(s)
I had mine out in about 2 hours. Now I have a whole other set of problems. Have you decided who is going to do your chip?
1996 F250 crew cab. Hypermax intercooler, Gearhead tunes, 4" exhaust, 6637 intake, Autometer gauges, Dana 60, 6.0 cooling fan, Built e40d, Firestone airbags, Full Force stage ones more to come. SOLD
2003 7.3 F250 Lariat. Mostly stock.
toad is offline
post #3 of 34 Old 07-03-2013, 09:18 PM Thread Starter
I am going to have DP do it. I am buying my injectors through them.
Hopefully nothing major with your rig. Just read your thread.
post #4 of 34 Old 07-04-2013, 07:05 AM
Quoted: 80 Post(s)
Feedback Score: 4 reviews
If you have everything you need tool wise should it should take 1 1/2-2 hrs max. Btw pull the rear injectors first so that all the oil and fuel run into those cylinders. Don't let the oil/fuel just sit in the cylinders, pump it out asap so that your crankcase oil doesn't get contaminated with fuel. The little marine drill driven oil change pumps with the 1/4" hose on them work perfect for pumping out the cylinders.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #5 of 34 Old 07-04-2013, 08:31 AM
toad's Avatar
Quoted: 16 Post(s)
When I did mine the rear one on the passenger side would not come out. It was hittiing the ac box. All you have to do is remove the silver padded thing on the ac box and there is a little vacuum box that bolts to the side of the ac housing. It is held on by a couple screws. It will make sense when you get to that point.
toad is offline
post #6 of 34 Old 07-04-2013, 08:32 AM
toad's Avatar
Quoted: 16 Post(s)
By the way my truck is fixed. Never felt so good to be a dumb ***
toad is offline
post #7 of 34 Old 07-04-2013, 09:00 AM Thread Starter
What was it?
post #8 of 34 Old 07-04-2013, 12:40 PM
toad's Avatar
Quoted: 16 Post(s)
POS Optima batteries.
toad is offline
post #9 of 34 Old 07-05-2013, 09:05 AM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
i found the biggest PITA was getting the injectors to pop free. need a long pry bar and if it slips you can smash your fingers pretty well.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #10 of 34 Old 07-05-2013, 04:39 PM Thread Starter
Where do you set the pry bar to pop out the injectors...I don't want to bust anything.
