I'm back...with no turn signals - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-03-2013, 06:16 PM Thread Starter
After learning about anti-theft systems and starting issues, I'm turning to my turn signal problem. They don't work inside or out but hazards do. There are no faulty bulbs. I replaced the flashers and turn signal arm in the steering column since it was worn and kinda sloppy.
-Austin
1996 F-250 XLT ECLB 4x4 w/E4OD 119k and counting
6637 intake
Diamond Eye 4" turbo-back exhaust
rebuilt tranny
1998 Buick Regal GS 149k
parts runner with blown head gasket
acprimus631C is offline
post #2 of 7 Old 07-03-2013, 06:36 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Tried the round fuse on back side of the fuse panel in the cab under the dash
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 7 Old 07-04-2013, 05:42 AM Thread Starter
Yes, along with the flasher. I already fixed one shorted wire that was rubbing on the battery tray but nothing is going on.
-Austin
6637 intake
rebuilt tranny
post #4 of 7 Old 07-04-2013, 09:22 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
There are 2 round flasher fuses and you have done both?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 7 Old 07-04-2013, 02:34 PM Thread Starter
The back-to-back ones in the lower right hand corner? Yes they are both new.
-Austin
6637 intake
rebuilt tranny
post #6 of 7 Old 07-05-2013, 04:54 PM
jake-96-7.3's Avatar
Send a message via Yahoo to jake-96-7.3
Column switch possibly have to find which wire on the harness gives voltage to the flasher or if u can get meter leads to the back relay on the box and read it there
1996 F250 ext cab long bed
AFE stage 2 intake
Ts6 chip Tw tunes
Isspro EV2 Gauges
Dacco billet cover triple clutch HD Torque converter
3in down pipe
5in straight pipe
6 in tip,
true cool 40,000btu trans cooler
203 thermostat
Firestone ride rite air bags in rear
tinted head lights turn signals markers sd tinted fogs
Kenwood head unit
full JL audio sound
jake-96-7.3 is offline
post #7 of 7 Old 07-06-2013, 05:41 PM Thread Starter
I need to learn how to use a meter I've already put in the switch asembly in the column and didn't see anything weird.
Anywho, going to the shop Monday or Tuesday to get my alarm taken out so I will have them look at it then. Tomorrow is beach day!
-Austin
6637 intake
rebuilt tranny
