1997 e4od-zf5 swap, need advice/help - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-01-2013, 04:34 PM Thread Starter
strokin95style's Avatar
OK, I am trying to round everything up I need to do my zf5 swap. I have the transmission, cross member, clutch, solid flywheel, shifter handle, transfer-case linkage, clutch/brake pedal assembly, steering column, slave cylinder, line, and reservoir... Now, the donor truck is a 1990 f-350 rclb 7.3 zf5 4x4, will (1)the harness for the transmission hook up to the harness on my 97 f250 7.3 4x4 auto? (2) will I need an idm or ecm from a 5 speed truck or will I be ok with the stock ones, (3) Will the neutral safety switch wiring in the 1990 work in my 97? If not what will it take to make it look as if its factory? (3) Does anyone know how much shorter the zf5 is than the e4od, and how long the rear drive shaft will need to be lengthened? I have the front half of a drive shaft from a 1995 f250 2wd 7.3 5 speed that had a 2 piece shaft. it is roughly 3-4 inches longer than the front half of the drive shaft in my ccsb. If anyone has any input on this, I would greatly appreciate it. I just want to make sure I have everything planned out and all the parts ready to just throw at it in one weekend. Thanks in advance guys.
Nater
1995 f-250 rclb
7.3~317k miles & countin
3" Downpipe
Superduty 10.5" 3 pinion Trac-Lok rear
Dana 60 s.a.s
1997 ccsb , 353,500 miles
5" lift on 315x75x16 cooper at3's.
Clear headlights, tinted tails, rear buckets,
Dana 60 swap, zf5 swap.
rosewood 180/100's, t500 hpop, php hydra, e fuel.
strokin95style is offline
post #2 of 9 Old 07-02-2013, 09:10 PM
you will either need a chip that is set to fool your ecm to thinking its a 5speed ecm or an actual 5sp ECM, the IDM is the same accross all trucks exept the variations in injector signal voltage.
i did this swap few years ago dont remember measurements though. but i do know i found a post on here that said the differences.
i beleive the Neutral Safety Switch or "Clutch switch" is actualy already in the vehicle under the carpet with a factory Bypass wire already in it. i cant fully remember though.
i had also gotten the floor pan out of a donor truck so that way i didnt have to cut the floor. salvage lot let it go for 15$ didnt bother me as i then had to do no measurements for cuts.
your truck will run with the Auto ECM but you will have no cruise control and OD light on shifter will always be on. my truck "96" ran like a champ no limp mode or anything. you need a different harness for the Manual then the Auto also if you want reverse lights and such. the auto harness unplugs from the main harness and a manual's harness plugs right back in if i remember right.
i now have a 96 4DR regular box auto that i will most definately do a zf5 or zf6 swap into ....althought unlike my first ill wait till the auto dies before doing it as i have more then 1 vehicle now.
96strokerlb is offline
post #3 of 9 Old 07-02-2013, 09:27 PM
and while im at it.. the ZF5... HUGE improvement on pulling EGT control over the E4OD
Joe
____________________________________________
1996 SCLB 7.3L Auto - ZF5 Swap, E-Fuel, Baldwin air, 10k Mod, Rosewood Stage 1s, 17* HPOP -=-Sold-=-
1996 CC 7.3L Auto - Banks intercooler " 2 grand its home 6-28-13 needs Fpump and redone exhaust manifolds. to be finished soon
1967 Ford Fairlane 390and FE BBlock - 500HP playtoy
2012 F-150, bone stock.
post #4 of 9 Old 07-02-2013, 09:59 PM
Quoted: 43 Post(s)
The wiring and connector for the clutch switch are there. In the automatic trucks, the connector has a jumper block that permanently closes both the cruise and start circuits. You could leave that block in place, but (1) the cruise won't interrupt when you hit the clutch, and the engine will redline, and (2) you'll be able to start it in gear with the clutch engaged. **SOME** new master cylinders (or complete hydraulic kits, if you choose that route) have the clutch switch included on the pushrod. If you're getting the master off a donor truck, it might have the switch already. In that case, you'd just remove the jumper and plug the connector into the switch, and Bob's your uncle. You'll need a reverse light pigtail to splice into the reverse light wires on the existing connector that used to go to the auto tranny. If the donor truck is junk, you could just cut it off that truck, but they're only a few bucks at RockAuto.
...except the shifter won't be there ...
madpogue is online now
post #5 of 9 Old 07-02-2013, 10:44 PM Thread Starter
Awesome info. The only thing missing from the donor truck before I got it was the bed. So the wires I will need, being from. '90 "should" work on my 97?
Nater
1995 f-250 rclb
3" Downpipe
Dana 60 s.a.s
post #6 of 9 Old 06-09-2015, 06:20 PM
i have a 97 did the swap and changed the pcm but im still getting the auto codes and the truck lops when i start it help please
7.3 fourdoor is offline
post #7 of 9 Old 06-09-2015, 06:28 PM
i swaped my atuo to a five speed changed the ecm and still getting the auto codes and truck lopes when i start it help please it a 97
post #8 of 9 Old 06-09-2015, 06:34 PM
Quoted: 43 Post(s)
1) This warrants starting a new thread.
2) This is not chat. Your posts will be referenced forever, by people we'll never meet long after we're all dead. They will appreciate complete sentences.
3) What is the PCM code of the PCM you installed?
post #9 of 9 Old 06-09-2015, 06:39 PM
sorry i dont understand this site
Tags
e40d , zf5
