Engine oil dipstick tube has smoke/exhaust coming from it - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-01-2013, 07:58 AM Thread Starter
blackgold9838's Avatar
Hello all:
Being relatively new to owning a diesel I have a few questions! My 96 F350 cc 4wd 7.3 PSD Centaurus 2 has about 112000 miles on a new engine. The previous owner had the engine swapped (not sure why). Whenever I stop for fuel and check my oil level, I can see the dipstick has dislodged a bit in the tube and there is smoke/exhaust coming from the tube. The truck doesn't have any major oil leaks and the engine seems to run strong and sound good. It doesn't use a bunch of oil either. I have Shell T6 synthetic in it right now. Any ideas?
Sent from AutoGuide.com App
blackgold9838 is offline
post #2 of 4 Old 07-01-2013, 08:01 AM Thread Starter
Oh and here is a picture of the truck. Engine oil dipstick tube has smoke/exhaust coming from it-imageuploadedbyautoguide1372694453.569487.jpg
post #3 of 4 Old 07-01-2013, 08:06 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Ugh, Smoke/haze from the dipstick tube is normal. Since the dipstick is slightly blown out of the tube can mean mostly two different things. Best case scenario is that your CCV is plugged and you need to clean it out. Worst case is that you have excessive piston blowby and at least one of the slugs is not holding pressure on the power stroke. The CCV fix is easy, the blowby is not. I wish you luck on it being the CCV.
She's a Beaut!
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 4 Old 07-01-2013, 03:05 PM Thread Starter
Thanks for the compliment! It was basically love at first sight! I've always wanted an obs and had a 94 f250 gasser but I wanted to switch it up to diesel and 4 x 4. I wish I would have washed it before I snapped the picture but hey, she's a farm rig ! I will check my ccv when I get home. I'm not really into performance mods, I just want longevity and dependability.
